RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - pashutik - 12-16-2016
Hi,
please help me, i use 2016.09
i change all folders, start menu offline. All steps done. but can't find in xentry simulator offline programming select
[Image: IMG_3929.jpg]хостинг картинок бесплатный
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - Mackhack - 12-16-2016
Control Unit "name"/Adaptation/programming
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - pesona - 12-16-2016
@pashutik retrofit not covered yet
(12-16-2016, 06:27 AM)pesona Wrote: @pashutik retrofit not covered yet
Is this something you're actually working on?
in spare time, to reduce stress after work, i play with some hidden function especially in das.
retrofit is one of the list but i have not touch it yet.
renew ecu (except tricore) using das is more interesting. i know vvdi' users laugh but anyway it is just a refreshing for me.
RE: PKW/SMART Programming Offline 12/2015 & 2016 - Greck81uk - 12-16-2016
(07-26-2016, 07:39 PM)alexjx Wrote: thanks for the great share!
and i found out i am damned.
i have applied the "no password and offline programming" patch without backing up first.
is there anyway i can undo everything? i am on xdos 05-2016 (x64)
which files should i rename/edit?
thanks!
How does this patch affect offline programming?
Dear Pesona,
I came up across a problem while testing SMART offline programming in simulation mode.
Can you please try and explain what the problem is?
I have "Special Functions password free" patch from DieTRih installed
OpenShell 07/16
Thanks in advance
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - pesona - 12-17-2016
it is normal mate. we will get that in simulation in many area when xentry/das try to get values from ecu and it gets outside specified values.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - gjergji - 12-28-2016
Hello,
So I have 09.2016
I see that the attachments are for: Offline Programming 2015 to 07-2016
Are these compatible with 09.2016. Anyone tried?
@pashutik were you able to fix it?
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - pesona - 12-29-2016
It should be okay for 09-2016, while @pashutik it is not covered yet.
