DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - Snozas - 01-06-2017 (01-06-2017, 12:50 AM)Mackhack Wrote: Go with Xentry or Vediamo with a legal version. Or go and pay for an official Daimler account and do it the right way via SCN. SCN has many advantages over offline. Might not be the answer you hoped for but it's a solution. Long term SCN is the way to go as Daimler is closing more and more glitches with each version they release. If you run a business do it like MB. Charge the customer 1 hour of labor for SCN. It's a cash cow for them. If they don't want to pay don't do the work. My MB dealership even denied my request to update my ME with a version that came out in 2007. Answer was it's not worth for us to do this. Many updates only take a fraction of that hour as you might have realized by now since you do it yourself. I will do the update via SCN myself. Thanks for reply. Definately not the answer for me. Investment is not worth it and you would be surprised by what we do with used electric power steering by puting parts from BMW to MB and similar stuff for small money. If I refuse to do it competitors will do. Anyhow thanks again and waiting for other suggestions. Sent from my iPhone using Tapatalk RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - dec-teck - 01-14-2017 Hello Folks i check many time all Flies But i have many times this Fault i got Xentry 07.2016 RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - Mackhack - 01-14-2017 You are in Sim mode. What do you want to flash in Sim mode since no actual control units are connected. Btw this is not a fault, it's part of the actual flash process. It's valuable information written in German. RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - dec-teck - 01-15-2017 I want to flash offline door unit I got the same message in normal mode BTW I do step by step Persona intructon do make xentry/das offline But it is always on online mode RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - Mackhack - 01-15-2017 Just hit F... to keep going through the menus until it starts. I flashed probably close to a 100 different modules in different cars with his modified files without a glitch. RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - stefy_hgs - 01-15-2017 (01-05-2017, 05:16 AM)Mackhack Wrote: Yes with a valid official Daimler account. No offence taken, my friend. I apreciate the good taughts and the help I can always find on this forum. So, Thank You verry much!!! RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - Dronx81 - 01-24-2017 Hi, is possible with this patch, scn offline programming for ecu edc16 and airbag smart 451 cdi 0.8? RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - pesona - 01-25-2017 the menu of scn offline will be appear but common wisdom by the experienced said it is no. i had the idea of this long time ago that i take the scn coding of the old ecu and entry it for the new one, it should be okay. but i can not prove it by simulation
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - gjergji - 01-25-2017 I had today a W204 in the garage. I could not do offline coding. The option was not available. I have XDOS 09.2016 Any help? |
