RE: Support thread for FullFixbySamik payed version - Sam!k - 03-28-2025
(03-27-2025, 07:13 PM)bronze_q8 Wrote: Hello, I bought key for FullFix 7.2.5 a month ago and now the Xentry does not work, so I formatted the laptop and now FullFix 7.2.5 does not accept the key I entered previously. Why? Same laptop, same version of Windows, same version of Xentry and same FullFix.
Key is for one system.
Not for laptop, not for windows, not for user, not for Xentry. It's for one system use.
If key didn't accept, need buy new key or use free version.
RE: Support thread for FullFixbySamik payed version - Savrseno - 04-01-2025
one system means only for one time use?
RE: Support thread for FullFixbySamik payed version - Sam!k - 04-01-2025
(04-01-2025, 09:06 PM)Savrseno Wrote: one system means only for one time use?
I need your help bro.
Please tell me, what i should add here:
Quote:Key is for one system!
It's not for laptop, not for windows, not for Xentry and not for windows!
It means after formatting system, it can be accepted and can not be accepted, if it's not, need to buy new one.
To didn't read such questions anymore?
RE: Support thread for FullFixbySamik payed version - Savrseno - 04-03-2025
you need to add for example what do you mean by "system" what is system?? if it is not laptop and not operating system then what is system then?????????????????????????
"it can be accepted and can not be accepted" which kind of answer is this??? i need CLEAR answer not can be or can not be!!!!!!! i can only see here feedbacks about not accepted key after same windows reinstalled on same laptop thats why i asked is it for one time use???? and if it is not accepted and it is not for one time use then what should be done to keep "system" same like it was before?
RE: Support thread for FullFixbySamik payed version - Sam!k - 04-03-2025
(04-03-2025, 09:12 PM)Savrseno Wrote: you need to add for example what do you mean by "system" what is system?? if it is not laptop and not operating system then what is system then?????????????????????????
If all that difficult for you, so just think it's one time use.
RE: Support thread for FullFixbySamik payed version - NewDriver - 04-03-2025
I just installed FullFix 8.1.5 with Xentry 2025.03. But i can't find the SD Connect Tool Kit.
How can i install SD connect ToolKit ?
(04-03-2025, 10:16 PM)NewDriver Wrote: I just installed FullFix 8.1.5 with Xentry 2025.03. But i can't find the SD Connect Tool Kit.
As you did it always: run ConfigAssist and select SDConnect mode.
RE: Support thread for FullFixbySamik payed version - NewDriver - 04-06-2025
It is works now. Thanks for your advise.
By the way, Full Fix 8.15, i found that no XentryENET Benjamin solution.   How can i install this ?  Or just install separately ?
RE: Support thread for FullFixbySamik payed version - Sam!k - 04-06-2025
It didn't work with 2025.
