RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - sergdk - 01-25-2017
Hello!
I am in simulation: Smart 451. Flashen is updated
I get error when I select Offline:
Error loading control table
Error Loading CNT file.
xentry 05-2015
SOLVED: missing files in flashen/sgcsd :-)
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - pesona - 01-26-2017
(01-25-2017, 09:40 PM)gjergji Wrote: I had today a W204 in the garage.
I could not do offline coding. The option was not available. I have XDOS 09.2016
Any help?
hi gjergji,
you have to install 204 menu in DAS (search in the forum). and if your 204 type is in the menu list, than you can do offline programming (update firmware).
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - TIGRI007 - 01-31-2017
Dears,
Sorry if my question is not very strict fulfill the subject, but I can not find a clear guide of replacing the cluster on smart 450 my2000 petrol with used one.
BTW I have (das with c3+ FVDI + Xprog)
Thank you very much in advance.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - Mackhack - 01-31-2017
Against my own believe of hi-jacking a thread that has absolutely nothing to do with your question...
Zero out the used one, CI initial startup, automatic..., take the old one out new one in, finish initial startup, done.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - Rumper - 02-01-2017
12/2016 on the work? Thank you
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - pesona - 02-01-2017
@Rumper
it should be okay with 12-2016. but it would be great if you install it in 12-2016 and give feedback.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - Jurgen02 - 02-01-2017
yes pesona,i can confirm
it works great witch 12/2016 version
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - ajpds - 02-03-2017
hello
I have this problem in smart 451
please help
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - pesona - 02-03-2017
try look in smart folder of other sdflash version especially from 2014-2015 that have etn*.*
i.e in sdflash\release\smart\
after that copy that 'smart folder' to your current sdflash folder.
don't forget to backup.
or hope smart car experts lurk in and help you.
