RE: Support thread for FullFixbySamik payed version - rotvajs - 04-06-2025
(04-06-2025, 10:49 AM)Sam!k Wrote:
(04-06-2025, 07:15 AM)NewDriver Wrote:
(04-03-2025, 10:24 PM)Sam!k Wrote:
(04-03-2025, 10:16 PM)NewDriver Wrote: I just installed FullFix 8.1.5 with Xentry 2025.03. But i can't find the SD Connect Tool Kit.
How can i install SD connect ToolKit ?
As you did it always: run ConfigAssist and select SDConnect mode.
It is works now. Thanks for your advise.
By the way, Full Fix 8.15, i found that no XentryENET Benjamin solution.   How can i install this ?  Or just install separately ?
It didn't work with 2025.
[font="MHH Font", Calibri, sans-serif]Hello people,[/font]
[font="MHH Font", Calibri, sans-serif]I installed "DualBoot" win 11 and I installed xentry 7/2024 Truck and 9/2024 car. I use interface M6 and everything works fine with DAS, but xentry does not want to communicate with interface.[/font]
[font="MHH Font", Calibri, sans-serif]I can't find a solution, can someone help.[/font]
[font="MHH Font", Calibri, sans-serif]Thanks[/font]
Hello people,
RE: Support thread for FullFixbySamik payed version - Sam!k - 04-07-2025
(04-06-2025, 11:54 PM)rotvajs Wrote: Hello people,
Is that about my Toolkit or you make it yourself?
RE: Support thread for FullFixbySamik payed version - rotvajs - 04-07-2025
yes i worked with your toolkit v4.6.1
RE: Support thread for FullFixbySamik payed version - hgmdiag - 04-07-2025
(09-22-2024, 10:37 PM)Sam!k Wrote: If you have purchased FullFixbySamik payed version and have some problem, write all your problem and questions here.
Don't write that in selling section, because as sad
fantomel, it's selling section and not support.
Different between free and not free vertions:
1. Xentry and Daimler Truck working with SDConnect.
2. Easy Installation of DTS Monaco 9.
3. Xentry, Daimler Truck and WIS 07.2021 automatic activation.
4. Fix for Xentry Update Service (XUS).
5. ZenZefi After-Sales_STANDARD certificates, for diagnostic new models.
6. "Actuations" tab for trucks, in Xentry and Daimler Truck.
Key is for one system!
It's not for laptop, not for windows, not for Xentry and not for windows!
It means after formatting system, it can be accepted and can not be accepted,  if it's not, need to buy new one.
About fix, payment information you can read in selling section thread of FullFixbySamik last version.
hello
i just wanted to see , do you know why C6 xentry original doesn't connect to xentry 03.2025 Cars?  IT DOES NOT EVEN PAIR!
Do I have to install extra drivers or anything ? Could it be because multiplexer Cal.sli files are getting replaced when we apply the Fullfix PATCH?
or does it have anything to do with the license key ?
Thanks a lot .
RE: Support thread for FullFixbySamik payed version - Rocinante - 04-07-2025
Does your OEM VCI have the latest software on it?
RE: Support thread for FullFixbySamik payed version - Sam!k - 04-08-2025
(04-07-2025, 10:13 AM)rotvajs Wrote: yes i worked with your toolkit v4.6.1
That Toolkit version or fix?
If fix, so there's no Toolkit.
If Toolkit, so it's very old and it's normal that it's not working with new versions. But interesting where you got it?
RE: Support thread for FullFixbySamik payed version - Felipe17310017 - 04-12-2025
Hello Samik, I installed Xentry Passthru 03/25 following all the recommendations, but when I tried to scan a car, an X253 Xentry gave me an error code C003: authentication has failed.
I tried to reinstall Xentry Fix, but I keep having the same error.
RE: Support thread for FullFixbySamik payed version - Sam!k - 04-12-2025
(04-12-2025, 05:49 PM)Felipe17310017 Wrote: Hello Samik, I installed Xentry Passthru 03/25 following all the recommendations, but when I tried to scan a car, an X253 Xentry gave me an error code C003: authentication has failed.
At the first, you need to understand what about that error!
It means Xentry or EZS didn't see valid certificate, it can be:
1. Didn't work ZenZefi server.
2. There's no valid diagnosis certificate in ZenZefi for current offline user account!!!
3. Date in EZS is wrong.
If it's 3-th option, so there's nothing to do with system or Xentry, need to work with car.
RE: Support thread for FullFixbySamik payed version - macbut999 - 04-21-2025
I am using XDOS 09/23 but Xentry and Xentry Sim are not working. Splash screen appears for 10 seconds and then disappears,but program doesnt start
. Truck and Truck Sim will open though.
