RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - ajpds - 02-04-2017
(02-03-2017, 09:15 PM)pesona Wrote: try look in smart folder of other sdflash version especially from 2014-2015 that have etn*.*
i.e in sdflash\release\smart\
after that copy that 'smart folder' to your current sdflash folder.
don't forget to backup.
or hope smart car experts lurk in and help you.
it is possible you help ?? because not work ...
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - pesona - 02-04-2017
pm audiomeca or jokeriphone. they are some of the experts in smart vehicles.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - Fabiuz - 02-09-2017
I need to coding a new sam virgin in Smart 451 my2009. It's possible or not?
Now i have select OFFLINE Coding but see "INSERT VecDoc DVD"
DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - mobileclimate - 02-17-2017
To fix missing ETN 906 and VeDoc for sprinter vans (2007-2009 Dodge sprinter)- you can just add the 906 etn files to the sd flash folder
I attched a pic of missing ETN for 906 van
and missing Vedoc
Sent from my iPhone using Tapatalk Pro[attachment=169458][attachment=169458][attachment=169459][attachment=169460][attachment=169537][attachment=169581][attachment=169582][attachment=169584]
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - Dronx81 - 02-21-2017
I tryed this guide with xentry 09/2016 and pwk+smart, i have copied into flashen folder but when i try to program offline gearbox ecu 451. I receive who not find the flash file into the drive.
I have used all sdflash(2008,2009,2010,2011,2012,2013,2014,)iso mounted with alcohol. And one usb drive with cff file of ecu into directory. Principal
What can i resolve this problem?.
There is a directory where i put this file or folder for do understand to xentry where to get the files for offline programming?
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - pesona - 02-22-2017
hi Dronx81 mate,
if you already have the cff file asking by das, you can mount the sdflash iso or
copy that sdflash into
c:\program files (xxx)\mercedes-benz\sdflash\release\smart
don't forget to backup it first.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - Dronx81 - 02-22-2017
Yes i have the cff file but when insert flash file into directory correct...or mount the iso with this cff or usb pen drive with cff file on pc xentry give me " fhe file is not found...possible cause:
File is not compatible.
The cd or usb are damaged. Etc...
I cant activate offline programming.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - zioweb - 02-22-2017
Great work! Just an information: with this patch we can upgrade with the latest flash files included in DAS or there is always the problem of no VeDoc files because they're only online now?
mobileclimate has given us a great hint. i hope y'all that works with (cars, smart or transporter) would share your experiences with others.
