RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017 - mobileclimate - 03-03-2017
(03-02-2017, 07:46 PM)pesona Wrote:
(02-17-2017, 09:37 AM)mobileclimate Wrote: To fix missing ETN 906 and VeDoc for sprinter vans (2007-2009 Dodge sprinter)- offline programming must have 11/2013 FLASH DVD make a copy of sdflash release folder overwrite files with 11/2013 DVD and then copy the original back ...works perfect on 12/2016 xdos ...you can just make copy of profi_cd.ini of 12/2016 xdos and use 11/2013 and 07/2014 over write files in folder..works perfect in simulation and real with NO ERRORS at all
I attched a pic of missing ETN for 906 van
and missing Vedoc
Sent from my iPhone using Tapatalk Pro
hi mobileclimate,
thank you so much for your valuable feedback in offline Transporter programming.
with feedbacks from bulayooo (post no 28) and you, regarding offline Transporter programming, i update my first post in this thread with new transporter inbetrieb.
it covers ALL transporter type in DAS upto 03-2017 and with it, you don't need to mix and clutter your sdflash in your harddisk drive again.
you can mount your 2013 sdflash and/or 2012 and/or 2014 collections in virtual drive and 2016/2017 in harddisk drive and let DAS search the needed files in those ALL SDFlash.
For xdos 03-2017, all offline programming are still valid. Only need to patch one file in das\bin and one file in sdflash folder (optional).
I will update my first post asap.
maybe someone can help on how to repair this error
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017 - pesona - 03-03-2017
hi mobileclimate,
what error in das you get? it looks like das doesn't get the needed file to update the ecu siemens vdo.
Viktor is known for his complete collections of cff files.
No error in das ..it says that the module already has the latest revision I'm just curious how it works ..what does the attrib.csv file do ? I can't find the ETN e fdoc file ..if you look at highlighting you'll see ETN error It looks like it's the file that makes sure the flash file is upgrading the right revision ? I need to hook up to some differ vans it might be because it's a dodge sprinter van ..I think the cdi module has a special revision
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017 - Mackhack - 03-03-2017
It simply compares what version is flashed already with a list of part numbers and its corresponding flashware version available on your system. If you actually spend some time with hexeditors and text file viewers you will start to understand the entire flash process. Involved are attrib.csv, akttab, cff and cbf files.
Try to flash with Vediamo. But if a control module is flashed with the most current version you cannot flash it again. Car control modules aren't updated as frequently as computer programs. Some control units will never see a single updat, others more frequently, some can't even be flashed.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017 - mobileclimate - 03-04-2017
(03-03-2017, 09:39 AM)Mackhack Wrote: It simply compares what version is flashed already with a list of part numbers and its corresponding flashware version available on your system. If you actually spend some time with hexeditors and text file viewers you will start to understand the entire flash process. Involved are attrib.csv, akttab, cff and cbf files.
I want to learn more about Vediamo.,i have been messing around with noteplad +++ java and sql stuff for years..i still want to know where that ETN e file is I cant find it
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017 - Mackhack - 03-04-2017
Vediamo has a very detailed help file on board. It really explains everything.
DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017 - mobileclimate - 03-06-2017
I do think it would be helpful if someone would have explained to look at the akttab.csv file and German language variant coding settings before flashing so if coding errors come up you can go and see what has changed and correct them back to original settings to avoid the online Scn coding
I see the akttab.csv is why that error comes up after coding because if doesn't have the correct coding on that file it could match the software revision not the coding after
DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017 - hassankwa - 03-07-2017
Hello please for the akttab folder do i need to copy and overwrite the folder cause i was getting some error messages
Thanks[Image: 8d67e5e057501501f84c94c2b5cce1d9.jpg]
Sent from my LGMS330 using Tapatalk
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017 - pesona - 03-07-2017
yes, you need to copy akttab.csv to your sdflash\release\pkw folder.
take it from other sdflash from xentry version near your xentry release or download from my first post of this thread.
