RE: Support thread for FullFixbySamik payed version - olluska - 05-28-2025 Installed XDOS 25.3.4 Installed FullFix 8.2.6 again Using china SdConnect C4 DOIP Problem is i cant connect to car, getting error (See image) Do we have to use Simulation or normal version? Simulation is letting me in, but not detecting car, or doing anything to the car. Reinstalling FullFix didnt work, what do i do wrong?? Need help.. VCI Icon on screen after installing again, so something is wrong? RE: Support thread for FullFixbySamik payed version - Sam!k - 05-28-2025 (05-28-2025, 06:52 PM)olluska Wrote: Installed XDOS 25.3.4 If you see VCI icon, it means you didn't switched to SDConnect mode. Let's start from that. If you look on desktop icons, i hope you can find SDC4-VCI Switcher app, run it, there's only two buttons for be more easy. RE: Support thread for FullFixbySamik payed version - olluska - 05-28-2025 (05-28-2025, 07:13 PM)Sam!k Wrote:(05-28-2025, 06:52 PM)olluska Wrote: Installed XDOS 25.3.4 Yes, after i press it, the VCI Icon disappears. What should i do next? Do i need to open Toolkit? RE: Support thread for FullFixbySamik payed version - NewDriver - 06-01-2025 Hi Sam!k, I used FullFix 8.1.2. Xentry login successful. I keep Xentry running then open a ZenZeFi Ui Web but no certificate. I tried to import but failed. Pls advise me how to fix it. RE: Support thread for FullFixbySamik payed version - Sam!k - 06-01-2025 (06-01-2025, 08:56 PM)NewDriver Wrote: Hi Sam!k,Always use latest version! (05-28-2025, 07:15 PM)olluska Wrote: Yes, after i press it, the VCI Icon disappears. Next as usual you did in old versions. RE: Support thread for FullFixbySamik payed version - NewDriver - 06-04-2025 (06-01-2025, 09:16 PM)Sam!k Wrote:(06-01-2025, 08:56 PM)NewDriver Wrote: Hi Sam!k,Always use latest version! Always use latest version! <--- I bought and instaleld it couple months ago. Can i still use the key to re-install with latest fullfix version ? Or else, how can i fix this ZenZeFi certificate issue ? RE: Support thread for FullFixbySamik payed version - Sam!k - 06-04-2025 (06-04-2025, 09:07 AM)NewDriver Wrote: Always use latest version! <--- I bought and instaleld it couple months ago. Can i still use the key to re-install with latest fullfix version ? Or else, how can i fix this ZenZeFi certificate issue ? If ZenZefi server running and you can see offline account there, then no need to reinstall anything. If HWID of your laptop didn't changed, yes you can download latest version and it shouldn't ask key. RE: Support thread for FullFixbySamik payed version - Rocinante - 06-04-2025 (06-04-2025, 11:03 AM)Sam!k Wrote:(06-04-2025, 09:07 AM)NewDriver Wrote: Always use latest version! <--- I bought and instaleld it couple months ago. Can i still use the key to re-install with latest fullfix version ? Or else, how can i fix this ZenZeFi certificate issue ? Does your HWID change with a format and fresh Windows installation? No hardware change in the laptop. RE: Support thread for FullFixbySamik payed version - Sam!k - 06-04-2025 (06-04-2025, 06:30 PM)Rocinante Wrote: Does your HWID change with a format and fresh Windows installation? No hardware change in the laptop. Fix's activation system a bit different then Xentry's and he use other things to make HWID, so HWID for Xentry and HWID for Fix are different. And yes, after formatting system, HWID for Fix is changing. |
