RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017 - Geka - 05-31-2017
Ok guys,i got a stupid questions for ya all! Big Grin
I copy files and replace folders and stuff and i give it a test in Xentry Simulation,so it DOES show the Offline programming as an option BUT no matter which VIN i put,either it is a Sprinter or a PKW,it pops a message,for example on Sprinter it says "ETK 906 vin series model not found." and then it prompts to incert a CD.
To explain,i never tested it before on real car,only in simulation to see how it works before i explode any ECU. Big Grin
So the stupid questions i got for you all is:Offline programming works only in real cars?Or it should also work in simulation and i do sth wrong???
I repeat i never tried it so far on real car,only Simulation...
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017 - Mackhack - 05-31-2017
Simulation does have odd behaviors. Patched or not. Simulator also uses totally outdated data and is mostly incorrect compared to working on a live vehicle. I flashed many cars offline with this solution and never had an issue.
After ECU updates i perform SCN coding though to make sure all parameters are set correctly.
So,if i have the correct files and folders inputed to their places for Offline programming and the profi_cd.ini files for online SCN they both work at the same time?
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017 - pesona - 06-01-2017
i have uploaded a simple menu, so you can switch between offline or original contents for online.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017 - Geka - 06-01-2017
(06-01-2017, 05:58 AM)pesona Wrote: i have uploaded a simple menu, so you can switch between offline or original contents for online.
So in order to do offline i need the original profi_cd.ini files too?cuz for SCN the only thing you change is this file to avoid VPO errors.Basically i will test it later and post the results,maybe we don't need to change all folders and files but only the profi_cd.ini file.I'll keep you posted! Fing32
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017 - Karu - 06-09-2017
Please add to OP- From DieTrih x64 XDOS Windows 7 install, "SDFlash" folder was missing in x32 Program files Mercedes-Benz folder. It is only present in x64 Mercedes-Benz install folder. All I had to do was copy "SDFlash" to C:\Program Files\Mercedes-Benz in order for menu to find PKW.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017 - Jake5555 - 06-15-2017
HI
I am getting mad.
I installed at my xentry/DAS 03/2015 system this patch but it does not würk.
I tried to do offline retrofit on my w208 but had no success.
once I tried it through DAS standalone and once through xentry into DAS.
got both times some error messages. --> See attached files
do you have a solution?
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017 - pesona - 06-15-2017
hi Jake5555 mate,
sorry, retrofit offline is not covered yet.
it is already answered here.
i update the first post with information regarding this.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017 - zaweel - 06-15-2017
Hello persona, it's so great what you are doing.
do you think retrofit offline will be covered later?
