RE: PKW/SMART Programming Offline 2015 & 2016. Tested work. - pesona - 07-28-2016
hi sisdisru,
look at your pkw sdflash folder, in this case is
c:\program files (x86)\mercedes-benz\sdflash\release\pkw
if there is already akttab.csv, then you don't need it.
if not, then copy only to pkw folder
this akttab.csv is only for pkw.
I've updated the w211 ETC MY 2008 but it didn't ask for release code which i do really hope i get.
I use C3 with XDOS (x32) 07-2016 which in its sdflash folder has an smr-f and cff file for that vehicle's ETC.
at first, i hesitate, C3 or SDConnect that I use. I choose C3 and hope still get the release code screen. Fing20 1087
I hope some experts in the pkw field will tell me how to get stuck with that release code.
for the time being, I will learn the log file i get from this process.
RE: PKW/SMART Programming Offline 2015 & 2016. Tested work. - schou - 07-28-2016
I programming a w211 MY2005's ME97 engine control module with your solution, it didn't ask for release code neither.
I use C4 with XDOS(x86) 07-2016
RE: PKW/SMART Programming Offline 2015 & 2016. Tested work. - alexjx - 07-28-2016
(07-28-2016, 05:12 PM)schou Wrote: I programming a w211 MY2005's ME97 engine control module with your solution, it didn't ask for release code neither.
me control unit?
did it ask for a scn coding after everything?
RE: PKW/SMART Programming Offline 2015 & 2016. Tested work. - heiko_audi - 07-29-2016
Today I tried your solution on W219 CLS. I can choose now online or offline programming. So everything should be fine. But when I try to upgrade MEG on smart 450, then I get error message:
"Error: Service ´MainSmartFlashRelease´ not found"
What could be the problem? I´m working on 12-2015 native install win XP Compaq Evo N410c with C3 mux.
Thanks in advance.
Greetings.
RE: PKW/SMART Programming Offline 2015 + 2016. Tested work and updated. - pesona - 07-29-2016
hi heiko_audi mate,
thanks for your feedback. I've updated my first post.
if you do offline programming in real, please give feedback.
RE: PKW/SMART Offline Programming 2014+2015+2016. Tested work and updated. - heiko_audi - 08-03-2016
I´m on holiday now. I can test your solution on smart in 2 weeks. I will post result here, thanks again.
Greetings...
RE: PKW/SMART Offline Programming 2014+2015+2016. Tested work and updated. - pesona - 08-07-2016
btw,
i have found the files that make online/offline programming EGS2 and EGS3 need seed key (Release Code). I will try to look at it, and solve it if i can.
Please give me information, if other ecu(s) needs seed key in offline programming.
as you know, probably, Daimler spy this forum, is it wise if i do this?
RE: PKW/SMART Offline Programming 2014+2015+2016. Tested work and updated. - Marcos - 08-07-2016
(08-07-2016, 06:51 AM)pesona Wrote: I've updated my first post.
btw,
If you'll be able to fix it it will be great.
Once done, share it privately and not public.
Cheers Smile
