[Solved] C3 is not connecting with W204 - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: [Solved] C3 is not connecting with W204 (/Thread-Solved-C3-is-not-connecting-with-W204) |
RE: C3 is not connecting with W204 - Kim1980 - 10-10-2016 I see in your error screenshot in the bottom status bar shows SD Connect MUX icon but not C3 MUX, C3 and SD Connect uses different hard drive. It is the correct hard drive? RE: C3 is not connecting with W204 - Decodec - 10-10-2016 (10-10-2016, 11:05 AM)Kim1980 Wrote: I see in your error screenshot in the bottom status bar shows SD Connect MUX icon but not C3 MUX, C3 and SD Connect uses different hard drive. It is the correct hard drive? Yes, I always use this drive with C3 mux, and there is no problem with connect to other models as I noticed in 1st post. Probably the software on this hard drive is an universal image to C3/SDConnect that seller gave me with laptop :s After work I'll try to enable W204 in DAS, maybe it will give an effect. If not, maybe I should use older Xentry (for example 09/2014)? Any more ideas are welcomed
RE: C3 is not connecting with W204 - laco210 - 10-10-2016 First try in toolkit.ini delete line skipcomports=all and set line usecomport=2 then you will see in SDconnect toolkit PartD on display after mux connection. RE: C3 is not connecting with W204 - asimor - 10-11-2016 Change folder BIN to PartD
RE: C3 is not connecting with W204 - Decodec - 10-12-2016 (10-10-2016, 01:30 PM)laco210 Wrote: First try in toolkit.ini delete line skipcomports=all and set line usecomport=2 then you will see in SDconnect toolkit PartD on display after mux connection. Nothing changes :/ (edit - there was no change because I didn't restarted system. After restart work perfect )(10-11-2016, 06:43 PM)asimor Wrote: Change folder BIN to PartD Which folder? Can you explain more detail? RE: C3 is not connecting with W204 - SmartM - 10-12-2016 Hello Decodec, please copy this two files in the attachment to path--F:\Programme\xentry\llist\ RE: C3 is not connecting with W204 - skbcar - 10-12-2016 only one C4 ~~ RE: C3 is not connecting with W204 - Decodec - 10-12-2016 (10-12-2016, 03:20 PM)SmartM Wrote: Hello Decodec, Hello SmartM, You attached 2 files: csl.sli and cal(1).sli Do I have to rename cal(1).sli to cal.sli and replace existing file in this folder? Thanks RE: C3 is not connecting with W204 - laco210 - 10-12-2016 First save your original file for sure Try look into C:\Userdata\Config\Xentry\driver - slave.ini and set there com port which you have used for PartD |
