722.9 Conductor Plate question - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: 722.9 Conductor Plate question (/Thread-722-9-Conductor-Plate-question) |
RE: 722.9 Conductor Plate question - Anturage - 11-04-2016 (11-03-2016, 08:25 PM)EASatlanta Wrote: EHS P/N: 2202701206Read 104 footnote in EPC RE: 722.9 Conductor Plate question - EASatlanta - 11-04-2016 (11-04-2016, 02:08 AM)Anturage Wrote:(11-03-2016, 08:25 PM)EASatlanta Wrote: EHS P/N: 2202701206Read 104 footnote in EPC ![]() I'm not sure what that means. RE: 722.9 Conductor Plate question - alexjx - 11-04-2016 (11-03-2016, 09:19 PM)EASatlanta Wrote:(11-03-2016, 09:06 PM)alexjx Wrote:(11-03-2016, 08:54 PM)EASatlanta Wrote:(11-03-2016, 08:37 PM)alexjx Wrote: how many faults are there? yes. 2/3 you can just change plate. 1, you must change the valve body together.
RE: 722.9 Conductor Plate question - RPM55 - 11-04-2016 Good morning, if you click on the fault code displayed on your SDS it will open the diagnostic tree and guide you through what needs to be done. If it tells you to pull the info from the control unit before proceeding then you need to replace the conductor plate/ control unit. If it doesn't tell you to pull the info then it leads to replacing the complete valve body. also be sure to replace all of the aluminum screws / bolts you remove because they are one use only. Cheers RE: 722.9 Conductor Plate question - salerka - 11-04-2016 (11-04-2016, 06:47 PM)RPM55 Wrote: Good morning, if you click on the fault code displayed on your SDS it will open the diagnostic tree and guide you through what needs to be done. If it tells you to pull the info from the control unit before proceeding then you need to replace the conductor plate/ control unit. If it doesn't tell you to pull the info then it leads to replacing the complete valve body. You mean all bolts from valve body must be changed? RE: 722.9 Conductor Plate question - alexjx - 11-04-2016 (11-04-2016, 09:08 PM)salerka Wrote:(11-04-2016, 06:47 PM)RPM55 Wrote: Good morning, if you click on the fault code displayed on your SDS it will open the diagnostic tree and guide you through what needs to be done. If it tells you to pull the info from the control unit before proceeding then you need to replace the conductor plate/ control unit. If it doesn't tell you to pull the info then it leads to replacing the complete valve body. yes. normally it will be included in the package. RE: 722.9 Conductor Plate question - salerka - 11-04-2016 But old bolts is usable after cleaning valve body? Because I dont see any difference betwen old and new. RE: 722.9 Conductor Plate question - EASatlanta - 11-04-2016 (11-04-2016, 09:50 PM)salerka Wrote: But old bolts is usable after cleaning valve body? Because I dont see any difference betwen old and new. Torqued aluminium bolts need replacement; if you call a good dealership they have the valve body, conductor plate, seal, pickup tube, filter, gasket, bolts and fluid all in one box RE: 722.9 Conductor Plate question - MBENZTECH - 11-04-2016 If you have Star Diagnostic all you have to do is process the code by hitting F3 and the diagnostic will let you know if you need valve body or conductor plate. Is that easy! |
