SD Connect & 09.2016 Problem Firmware & DAS Error - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: SD Connect & 09.2016 Problem Firmware & DAS Error (/Thread-SD-Connect-09-2016-Problem-Firmware-DAS-Error) |
RE: SD Connect & 09.2016 Problem Firmware & DAS Error - crashndash - 11-08-2016 could it be due to incorrect vehicle selected? Self test is ok from what I can make out ![]() Will have another go in the morning seemed to be all working at one point then that update message and the error in das popped up, really need it up and running first thing RE: SD Connect & 09.2016 Problem Firmware & DAS Error - yriy - 11-08-2016 not ok! ram no see your tool! RE: SD Connect & 09.2016 Problem Firmware & DAS Error - Anturage - 11-08-2016 Test has been terminated. SDConnect is dead. RE: SD Connect & 09.2016 Problem Firmware & DAS Error - Marcos - 11-08-2016 (11-08-2016, 07:26 PM)Anturage Wrote: Test has been terminated. SDConnect is dead. Does it happens to know what is wrong with it? Which component is broke and if it can be repaired? Cheers
RE: SD Connect & 09.2016 Problem Firmware & DAS Error - crashndash - 11-09-2016 (11-08-2016, 03:38 PM)yriy Wrote: not ok! ram no see your tool! What do you mean by Ram not see it? what would have killed it the software image from this thread surely not? RE: SD Connect & 09.2016 Problem Firmware & DAS Error - jokeriphone - 11-09-2016 The first step for you - You must change serial number of your MUX. Xentry don't love this number ! RE: SD Connect & 09.2016 Problem Firmware & DAS Error - crashndash - 11-09-2016 I have wiped the HDD was going to try a fresh install tomorrow, never had any troubles with the serial when I used 07.2016 software just since I had to change RE: SD Connect & 09.2016 Problem Firmware & DAS Error - Anturage - 11-09-2016 (11-08-2016, 11:14 PM)Marcos Wrote: Does it happens to know what is wrong with it? Which component is broke and if it can be repaired?Nobody tell you this without opening and hardware testing. One more china piece of shit will be trashed i think. RE: SD Connect & 09.2016 Problem Firmware & DAS Error - Marcos - 11-09-2016 (11-09-2016, 03:04 AM)Anturage Wrote:(11-08-2016, 11:14 PM)Marcos Wrote: Does it happens to know what is wrong with it? Which component is broke and if it can be repaired?Nobody tell you this without opening and hardware testing. I agree. But what if it is not actually a hardware problem? Have you thought that it can be a corrupted firmware on it? Why it can be like this? Because strange enough these errors and tests failed comes up as soon as some firmware is trying to update
