w221 cannot teach-in ISM - Printable Version
+---- Thread: w221 cannot teach-in ISM (/Thread-w221-cannot-teach-in-ISM)
Pages: 1 2 3
RE: w221 cannot teach-in ISM - Aless91 - 01-05-2017
(01-05-2017, 12:57 AM)KriyenKPp Wrote: can avdi do this as well--virginise ?Fing32
Yes, there is also a video how to do it on youtube.
RE: w221 cannot teach-in ISM - Russell118 - 01-07-2017
(12-28-2016, 07:29 PM)EASatlanta Wrote: Hello guys,
Have w221 here, using 09/2016 that Yudi has checked over and I have successfully done SCN.
w221 came to me with no transmission in the car. We put used transmission with valve body. Performed SCN, success.
Trying to teach in ISM, ism fails. The first time I tried, it saw P for park, then would not let me move it to R or D.
Now when I try teach-in I get this error:
No communication 8.600.0
Any ideas? Fing20
[Image: QGfBpDO.jpg]
Did you manage to fix your problem?
RE: w221 cannot teach-in ISM - viktor - 01-07-2017
As I know ONLY CHANGE ISM on NEW or USED and RENEW UNIT
RE: w221 cannot teach-in ISM - EASatlanta - 01-08-2017
The customer hasn't chosen to fix the problem yet... I gave him two options, one including the price of an FVDI tool. I'll post what the solution is Smile
RE: w221 cannot teach-in ISM - Russell118 - 01-08-2017
on the valve body is a spring plate that tensions the "gear cog" for the gear selector. Are you sure that spring plate is fitted?
if its missing it will not program!
RE: w221 cannot teach-in ISM - XANDER1111 - 01-09-2017
module must be renewed. If you come from another vehicle, eg. W212 also need to reprogram on the W221. then perform the introduction of the right to drive and calibration. all you can perform offline .100% tested repeatedly
RE: w221 cannot teach-in ISM - EASatlanta - 01-09-2017
(01-08-2017, 05:46 PM)Russell118 Wrote: on the valve body is a spring plate that tensions the "gear cog" for the gear selector. Are you sure that spring plate is fitted?
going to have my technician double check this in the morning, thanks !
RE: w221 cannot teach-in ISM - 93r1 - 01-09-2017
Also selector sensor rod needs to be engaged properly
RE: w221 cannot teach-in ISM - gio777 - 01-09-2017
Hello first need renew ISM by fvdi after offline programing
