Unusual Error while SCN coding - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: Unusual Error while SCN coding (/Thread-Unusual-Error-while-SCN-coding) |
RE: Unusual Error while SCN coding - mickmaicol - 02-21-2014 (02-20-2014, 03:25 AM)petitepeste71 Wrote: Hi friend.. You have solved that problem? I have some error... My xentry 2014 version update with addons have proficd file different of the xentry 2014 basic installation.. Now i replace the file and i try to update the ECU gear with scn.. I have programmed with SCN coding on 722.9 with 11.2013 Xentry it looks for dvd software, I have inserted dvd software 11. 2013 but doesn't it accept, thing I have to insert? I have also tried dvd2 7. 2013 but it doesn't go RE: Unusual Error while SCN coding - argenta - 02-21-2014 (02-21-2014, 01:01 AM)mickmaicol Wrote: I have programmed with SCN coding on 722.9 with 11.2013 Xentry it looks for dvd software, I have inserted dvd software 11. 2013 but doesn't it accept, thing I have to insert? I have also tried dvd2 7. 2013 but it doesn't go hey, I have sent you a private message! go read ![]() let's see! RE: Unusual Error while SCN coding - iDIDNTdoIT - 02-21-2014 (02-21-2014, 04:10 PM)argenta Wrote:(02-21-2014, 01:01 AM)mickmaicol Wrote: I have programmed with SCN coding on 722.9 with 11.2013 Xentry it looks for dvd software, I have inserted dvd software 11. 2013 but doesn't it accept, thing I have to insert? I have also tried dvd2 7. 2013 but it doesn't go I just tried my first software update on ML ME2.8 controller and gives me same message to insert "CD labeled Star Diagnosis software", i have 09-2012 software version, where can i find the DVD, and what version DVD?? Thanks RE: Unusual Error while SCN coding - argenta - 02-21-2014 (02-21-2014, 05:49 PM)iDIDNTdoIT Wrote:(02-21-2014, 04:10 PM)argenta Wrote:(02-21-2014, 01:01 AM)mickmaicol Wrote: I have programmed with SCN coding on 722.9 with 11.2013 Xentry it looks for dvd software, I have inserted dvd software 11. 2013 but doesn't it accept, thing I have to insert? I have also tried dvd2 7. 2013 but it doesn't go ok well, try to do this... first solution: 1) take a spare usb drive or another media drive with at least 4 GB free space, or a blank DVD media. 2) in computer explorer point to the folder "F:\Programme\SDFlash\Release" 3) copy all whats inside that folder in the usb pen drive (or other device) you prepared earlier (or burn all that data to a new blank DVD) 4) when the message asking for the software shows up, point to the newly drive created ------------------------------------------------------------------------------------ If this still doesn't solve your problem, you can try this second solution: 1) COPY the whole "Sdflash" folder (found in path "F:\Programme") inside the path "F:\Programme\DAS" so that you will have also "F:\Programme\DAS\Sdflash" (NOTE: the directory name "Sdflash" is already there, but the folder is... EMPTY! Now you will overwrite and fill it. note: if you don't have enough space on drive F: to copy the "Sdflash" folder (which is almost 4 GB!), you can just MOVE it to the new location... eventually if something goes wrong you can always bring it to the position where it was originally. 2) in "F:\Programme\DAS\Sdflash\Release" path, edit the first part of the file sdflash.ini (make a backup, just in case!) to reflect the following: Code: [Directory]don't touch the last 2 lines you will see in that file, I mean FLASHDATAREGIO and FBV... they are OK, only modify the part reported ABOVE with the correct path (adding "\DAS\" folder...) It will not ask you anymore to insert the drive! and please if this message somehow helped you don't forget to click the reputation! --->
RE: Unusual Error while SCN coding - iDIDNTdoIT - 02-22-2014 Thank You, will try that. RE: Unusual Error while SCN coding - mickmaicol - 02-22-2014 resolved problem! ! ! ! thanks to you RE: Unusual Error while SCN coding - mercedessd - 03-14-2014 fix is to reinstall Flash files from install DVD. found in folder stardiag\SDFlash_Setup error seemed to return after reboot, i set the PKW folder and all contents as read only, so far so good. RE: Unusual Error while SCN coding - iDIDNTdoIT - 03-16-2014 Was away on vacation, just came back. I tried to burn the folder to a dvd but either the way it burned or something i wasn't doing right, it didn't work. I had copied the folder to a USB stick to burn on another computer, somehow Xentry found that folder on the USB and was able to continue. Turns out, latest was already installed, so nothing to update. Supposed to be a way to manually force it using develepor but couldn't figure it out. Thanks for the help. RE: Unusual Error while SCN coding - mercedessd - 03-19-2014 (03-14-2014, 01:16 AM)mercedessd Wrote: fix is to reinstall Flash files from install DVD. found in folder stardiag\SDFlash_Setup Since this thread was originally about the error "it was not possible to find path '<HDD installDir> profi_cd.ini' " I finally found a valid fix. today after I got the error I noticed there was an option to view a log, when I viewed the log I saw what was causing the error. so basically It was looking for a folder that was not there. it wanted to see the profi_cd.ini in a folder on the C: drive at the following location. C:\star\SDflash\Release\PKW\profi_cd.ini I basically copied all the files from the SDflash folder from F rogramme Once they were copied I tried to scn the 722.9 transmission again. it failed, was looking for another folder called cff, which it wanted at the following address, C:star\XentryDiagnostics\var\temp\Xentry\cffI created the folder at the specified location. rebooted computer and tried to scn again. this time it worked perfectly, no errors! followup. so after poking around and Rociante sending me some of his logs i found the issue was in the flash.ini located at F:\Programme\DAS\bin\Flashen it was set to this. [Directory] PKW=C:\star\SDflash\Release\PKW smart=C:\star\SDflash\Release\smart LKW=C:\star\SDflash\Release\LKW Transp=C:\star\SDflash\Release\Transp Unimog=C:\star\SDflash\Release\Unimog FUSO=C:\star\SDflash\Release\FUSO BharatBenz=C:\star\SDflash\Release\BharatBenz FLASHDATAREGIO=C:\star\SDflash\Release\Flashdataregio FBV=C:\Star\XentryDiagnostics\var\temp\Xentry\cff insted of this [Directory] PKW=F:\Programme\SDflash\Release\PKW LKW=F:\Programme\SDflash\Release\LKW Transp=F:\Programme\SDflash\Release\Transp smart=F:\Programme\SDflash\Release\SMART Unimog=F:\Programme\SDflash\Release\UNIMOG FUSO=F:\Programme\SDflash\Release\FUSO BharatBenz=F:\Programme\SDflash\Release\BharatBenz FLASHDATAREGIO=F:\ProgramData\FlashdataRegio FBV=E:\ProgramData\data\Xentry\Flashfiles notice the bottom entry? not sure how an older flash.ini was introduced to my files, but i think that is what happened. |
