SDconnect Toolkit INTEGRATION TO NEW XDOS VERSIONS 03/2024 & UP - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: SDconnect Toolkit INTEGRATION TO NEW XDOS VERSIONS 03/2024 & UP (/Thread-SDconnect-Toolkit-INTEGRATION-TO-NEW-XDOS-VERSIONS-03-2024-UP) |
RE: SDconnect Toolkit INTEGRATION FIX FOR NEW XDOS VERSIONS FROM 03/2024 - sheffpub - 05-01-2024 (04-12-2024, 02:15 PM)mhh0010 Wrote: Now to explain again: please tell me what corrections need to be made to make C4 work with xentry 03/24 ? RE: SDconnect Toolkit INTEGRATION FIX FOR NEW XDOS VERSIONS FROM 03/2024 - sheffpub - 05-02-2024 I already installed 03/24, and I can’t find a working solution for it. I can’t remove the crash in the engine control unit on a 167 GLE facelift diesel hybrid, I unlocked the high-voltage part, now the car is charging from the socket, but I can’t remove the crash from the engine and start it RE: SDconnect Toolkit INTEGRATION FIX FOR NEW XDOS VERSIONS FROM 03/2024 - BUGBEAR - 05-08-2024 I can confirm that it works. I have installed 03.2024 with SDConnect C4. It works in both wifi and Ethernet mode Thanks for the toolkit RE: SDconnect Toolkit INTEGRATION FIX FOR NEW XDOS VERSIONS FROM 03/2024 - jose breno - 05-08-2024 fix working perfectly https://youtu.be/wvR8jCxk_Po RE: SDconnect Toolkit INTEGRATION FIX FOR NEW XDOS VERSIONS FROM 03/2024 - scorpion4x4 - 05-10-2024 (05-08-2024, 01:29 PM)BUGBEAR Wrote: I can confirm that it works. I have installed 03.2024 with SDConnect C4. It works in both wifi and Ethernet mode Can you please explain how did you make it work? What fixes did you use? Regards RE: SDconnect Toolkit INTEGRATION FIX FOR NEW XDOS VERSIONS FROM 03/2024 - scorpion4x4 - 05-12-2024 (05-10-2024, 10:11 PM)scorpion4x4 Wrote:(05-08-2024, 01:29 PM)BUGBEAR Wrote: I can confirm that it works. I have installed 03.2024 with SDConnect C4. It works in both wifi and Ethernet mode I think i fugured it out, one have to edit CAL.ini and change part_Z to part_T (both \xentry\bin and DAS\bin). Haven't tested it with a car yet, but in the workbench Xentry and DAS can see SDconnect. Please test and confirm. RE: SDconnect Toolkit INTEGRATION FIX FOR NEW XDOS VERSIONS FROM 03/2024 - connector - 05-16-2024 (05-02-2024, 12:08 AM)sheffpub Wrote: I already installed 03/24, and I can’t find a working solution for it. I can’t remove the crash in the engine control unit on a 167 GLE facelift diesel hybrid, I unlocked the high-voltage part, now the car is charging from the socket, but I can’t remove the crash from the engine and start it These can be tricky. Crash signal can be in engine/ ptsu / powertrain/ srs/ radars/ airbag /etc etc. Sometimes this is very tricky to find. Do not worry about hermes crash signal. SOS still works 99% of the time. Hard to tell where the crash signal is. If you see a function about it, and it says its ok, reset it anyways. RE: SDconnect Toolkit INTEGRATION FIX FOR NEW XDOS VERSIONS FROM 03/2024 - Dublover - 05-24-2024 Like others replying in this post, can anyone, including the author, explain what modifications are actually required to allow this fix to work with XDOS 03/2024? I have modified the cal.ini file in xentry and das, to read Part_T however I still cannot communicate in Xentry (not tested DAS). The author states "Corresponding corrections must be available for "XENTRY" and "DAS standalone"! Read post #1 carefully." I have read post 1 many times, but I see no obvious explanation. Can I ask the Author, does he know what these "corrections" are? If so, is he willing to share the information? Many thank in advance RE: SDconnect Toolkit INTEGRATION FIX FOR NEW XDOS VERSIONS FROM 03/2024 - Jay - 07-01-2024 (05-12-2024, 06:24 PM)scorpion4x4 Wrote:(05-10-2024, 10:11 PM)scorpion4x4 Wrote:(05-08-2024, 01:29 PM)BUGBEAR Wrote: I can confirm that it works. I have installed 03.2024 with SDConnect C4. It works in both wifi and Ethernet mode |
