RE: Support thread for FullFixbySamik payed version - NewDriver - 10-11-2024
(10-11-2024, 11:20 AM)Sam!k Wrote:
(10-11-2024, 06:06 AM)NewDriver Wrote: Hi Samik,
I installed Xentry 2024.06 and configured IP 169.254.0.45/255.255.0.0 for C4DOIP but xentry failed to communicate.
You config only DoIP IP?
Which car you need to connect with this configs?
W212 old car.   Let me try to configure both IPs (172.29.127.x/255.255.0.0 and DoIP address) again and let you know.
RE: Support thread for FullFixbySamik payed version - Sam!k - 10-11-2024
I won't work with only DoIP IP with not DoIP cars!!!
Your problem not with my fix, just write right IP address for SDConnect, for example 172.29.127.127
Hello
I just now put both IP address together. Then SDconnect ToolKit > Administration > Initialization but still can't find the C4doip.
Xentry still got same problem.
Please advise,thanks
How i see in your screenshots, Toolkit didn't see SDConnect?
It have to see him in any case if it's connected!
Something with your connections.
(10-11-2024, 06:35 PM)Sam!k Wrote: Hiw i see in your screenshots, Toolkit didn't see SDConnect?
Do i need to install the fix for SDconnect ?  then run the ConfigAssist ?
When you install clean new Xentry, there's no Toolkit and doesn't matter did you run ConfigAssist or not.
After installing fix, you need run ConfigAssist and select SDConnect to switch SDConnect mode.
After that Toolkit will start automatically and even if you didn't write any IP address, Toolkit have to see SDConnect!
If didn't, it means you have some problem with ethernet adapter, lan cable or SDConnect.
RE: Support thread for FullFixbySamik payed version - PW00X - 10-12-2024
Will my key for v6.4.2 also work for v7.2.1.7?
RE: Support thread for FullFixbySamik payed version - Sam!k - 10-12-2024
(10-12-2024, 06:56 PM)PW00X Wrote: Will my key for v6.4.2 also work for v7.2.1.7?
No.
For your key latest version is v6.4.4
RE: Support thread for FullFixbySamik payed version - NewDriver - 10-13-2024
(10-11-2024, 08:41 PM)Sam!k Wrote: When you install clean new Xentry, there's no Toolkit and doesn't matter did you run ConfigAssist or not.
My laptop Ethernet adapter is working fine. I tested with Router via LAN cable this morning.  Please see attached photo.
My SDconnect is also working fine. I tested with another laptop.
Please tell me how to fix this SDConnect.  Thanks in advance.
