W211 Rear SAM module -how to repair it? - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: W211 Rear SAM module -how to repair it? (/Thread-W211-Rear-SAM-module-how-to-repair-it) Pages:
RE: W211 Rear SAM module -how to repair it? - sixcode - 04-04-2016 (04-04-2016, 08:27 PM)kmodel99 Wrote: You can try to connect it, and electronic modules, which is damaged should be very hot. Be careful when touching these elements, you can lose yours finger prints for that problem i use this: [attachment=121973][attachment=121974][attachment=121975][attachment=121976] RE: W211 Rear SAM module -how to repair it? - Flori Service - 04-05-2016 Repair friend after this defect and try the car with only 1% is the possibility to do the work
RE: W211 Rear SAM module -how to repair it? - kmodel99 - 04-05-2016 (04-04-2016, 08:37 PM)sixcode Wrote:(04-04-2016, 08:27 PM)kmodel99 Wrote: You can try to connect it, and electronic modules, which is damaged should be very hot. Be careful when touching these elements, you can lose yours finger prints Doesn't everybody have tools like this, but when I was writing post, I thinked about this. RE: W211 Rear SAM module -how to repair it? - sixcode - 04-05-2016 (04-05-2016, 12:33 AM)kmodel99 Wrote:(04-04-2016, 08:37 PM)sixcode Wrote:(04-04-2016, 08:27 PM)kmodel99 Wrote: You can try to connect it, and electronic modules, which is damaged should be very hot. Be careful when touching these elements, you can lose yours finger prints no not everyone uses tools like this, what tool you have? (04-05-2016, 12:06 AM)Flori Service Wrote: Repair friend after this defect and try the car with only 1% is the possibility to do the work correct but he does have to start somewhere... RE: W211 Rear SAM module -how to repair it? - Stephenlevi1981 - 04-22-2016 Connect power and grounds and use freeze spray, the heat should defrost the shorted component first. I would always start at the capacitors. RE: W211 Rear SAM module -how to repair it? - Mackhack - 09-05-2016 Caps have a bulged top if they went bad. They won't get hot. In the worst case they leak(ed) the acid and it looks like salt built up. Why trying to fix that stuff? It's cheaper and more reliable to get a used one for cheap on eBay. RE: W211 Rear SAM module -how to repair it? - floricanu - 12-11-2016 hi all Just a quick question and I know that maybe is not the right place I have problems with my Rear Sam on w211 2.7. Just wondering if I'll replace with a used one do I beed to recode on the car or will work without? Thanks RE: W211 Rear SAM module -how to repair it? - Mackhack - 12-11-2016 Just transfer the date if the old one to your new one. New one or used one will work as long as it has the same option per EPC such as EDW. Best thing is buy one with the same part number to be safe. |
