RE: Support thread for FullFixbySamik payed version - Benne01 - 06-19-2025
I have clean xentry 03.2024 with C4. I have installed latest fullfix v8.2.7.
The problem is i can't select SDConnect on ConfigAssist, there is only VCI option. (I have tried SDC4 Switcher with no effect)
RE: Support thread for FullFixbySamik payed version - Sam!k - 06-19-2025
(06-19-2025, 03:41 AM)Benne01 Wrote: I have clean xentry 03.2024 with C4. I have installed latest fullfix v8.2.7.
Latest version is 8.2.8 but it's not important for your problem.
When you run SDC4-VCI Switcher, you have to have working internet connection. If you have and still didn't work, try some VPN.
Okay, I have working internet + tried with VPN. Still same only VCI in ConfigAssist.
You don't need ConfigAssist, forgot about that and read description one more time!
If didn't helped, write Anydesk data PM.
RE: Support thread for FullFixbySamik payed version - malatesta - 06-27-2025
(06-07-2025, 12:09 AM)malatesta Wrote:
(06-07-2025, 12:05 AM)Sam!k Wrote:
(06-07-2025, 12:00 AM)malatesta Wrote: hi, I did a clean install of XDOS 09.23, used the fullfix with the code I bought, but when I start xentry truck I get this error.
But is it working with Xentry Cars?
same error
i cant fix it, any help pls?
RE: Support thread for FullFixbySamik payed version - Sam!k - 06-27-2025
same error
That's because you forgot to say that you install everything on virtual system.
Even virtual machine have Secure boot!
Check Secure boot, make sure you have AppID 252!
RE: Support thread for FullFixbySamik payed version - Fiorino - 07-01-2025
Hello,
I've installed S_DTPID_25.4.4 on fresh win10 x64, installed addons, then newest fix. Toolkit does not see sd4. IP configured... For checking I've turned off windows firewall. Could you help?
RE: Support thread for FullFixbySamik payed version - Sam!k - 07-01-2025
(07-01-2025, 10:24 AM)Fiorino Wrote: Hello,
Toolkit have to see SDConnect even without IP.
If firewall didn't block Toolkit, then you have mechanical problem: with ethernet adapter, lan cable, SDConnect.
RE: Support thread for FullFixbySamik payed version - Frenki1995 - 07-03-2025
Hi sweety!
Where can i update addons after xentry installation, before i activate your fix? I would like to dig around, but dont want to fck up the clean installation.
Thanks for the reply!
