RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017 - pesona - 02-01-2018
yes.
for your das version (04-2014), you only need to replace "inbetrieb.ini" with the "inbetrieb" with offline abflauf.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017 - jabran200 - 02-06-2018
Can anyone help me please.
I installed the offline patch to do initial startup on SAM unit but after loading the cd and finishing the update it wants to start coding keys but I get this error it can't find FM_main.cnt
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017 - momosam - 02-06-2018
(02-06-2018, 01:55 AM)jabran200 Wrote: Can anyone help me please.
Look for it in das\trees\pkw\flashen\csd
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017 - pesona - 02-06-2018
@jabran200 what is the version of your xentry/das?
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017 - jabran200 - 02-08-2018
(02-06-2018, 05:41 AM)pesona Wrote: @jabran200 what is the version of your xentry/das?
2017/12
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017 - Mackhack - 02-08-2018
Did you also replace the DAS.inf?
(02-08-2018, 06:19 AM)Mackhack Wrote: Did you also replace the DAS.inf?
Yes but I had to manually change the location of the language files in the inf because they were wrong.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017 - megacrazy - 02-09-2018
Thanks for putting work into this pesona.
Unfortunately I am having issues with programming Comand. I'm running into the same issue other people had, namely "Insert DVD Labeled Star Diagnostic" after going to "Offline Programming" and advancing through the first prompt.
Here's some info:
- I'm running 2016.5 off a Dell laptop, Windows 7
- "Offline" programming shows up after replacing the "Flashen" folder
- SDFlash.ini has correct links to the appropriate folders
- I have downloaded various ISOs from the SDFlash collection and mounted them, no change
- The Inbetrieb.ini file seems to have the correct paths, I've even added new ones after mounting the ISOs under different drive letters, no change
- Replaced the entire "Release" folder with one from the correct ISO. The one I had was slightly less files...still no change.
- The system doesn't seem to check the CD drive at all. I have a firmware cd in there and it doesn't even start spinning.
Any ideas on what to try next? Thanks!
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017 - pesona - 02-09-2018
well, i am sorry fellas. i have to admit, that it was one year ago and i never look at it yet.
i hope someone could shed some light.
i still follow this thread and will make an update, if i can find something useful to add.
i very appreciate all the feedback.
