RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017 - thanh1974 - 02-28-2018
(02-11-2018, 12:42 AM)Mackhack Wrote: Perfect. That's what I thought you did. You confirmed it. Thanks.
PM me original eCom prices please does have DoiP??
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017 - samoxaaa - 02-28-2018
(02-26-2018, 05:47 PM)j4g3d Wrote: 03.2018 is there solution?
http://mhhauto.com/Thread-03-2018-DAS-PKW-and-Transporter-Offline-and-Online-Patch
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017 - mitkot - 03-19-2018
Is this solution works on xdos 12/2017 32 bit?
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017 - pesona - 03-20-2018
@mitkot look at xzt feedback, it is okay with 2017 version.
fyi,
i use the "Release: 2015 until 12-2016 version" patch as is,
and "rename and copy" to my xdos 2018-03 version, it works.
i have tried to offline programming in simulation in pkw,smart and transporter, without any problem.
the secret key is indeed the contents of sdflash in our harddrive or in virtual drive.
beside offline programming, i re-live the das pkw retrofit online/offline just for education.
i guess it can be used with 2014-2018. i will upload later.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017+2018 - pesona - 03-21-2018
i update the first post with:
- added das PKW offline entry for retrofits & modifications
- added information regarding 03-2018 xdos that many members ask me
- added information regarding self-made sdflash
- i do facelift my first post Big Grin
This is new.
- i made for myself, a utility. I call it Flash finder.
i enter "MB Object Number" and i will get all CFF and or all SMR-F+*RL that are available including the location of those files.
and vice versa
if i enter CFF or SMR-F, i will get the MB Object-Number. (*SMR-F has a long way to go. Daimler laughs at me (and to you too)) Big Grin
I think, i will improve it by adding Baumuster/Baureihe in the entry option if i have to.
Because one MB Object Number, gives result for all CFF/SMR-F+*RL for all Baumuster/Baureihe.
It is interesting for me. It is a good reference to for Vediamo or DTS newbie.
It helps me to know if an ecu has an optional new update or not. (newbie indeed, Big Grin)
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017+2018 - tsimplas007 - 03-28-2018
I'm thinking to try my 1st offline programming update with the patch posted in this thread. I've read everything but I've got aquestion. What's up with SCN after the software update of a control unit? Isn't it necessary?
Best Regards
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017+2018 - Mackhack - 03-28-2018
Nope it’s not. SCN isn’t even the update. SCN and online control module update are two completely different things. SCN stands for Software Calibration Number and changes the behavior of control modules as well as enables/disables them or certain functions within. It also tells the vehicle that a control module has been added, removed or exchanged. But without write access to VeDoc it’s pretty worthless to even considered paying for an account.
(03-28-2018, 01:39 AM)Mackhack Wrote: Nope it’s not. SCN isn’t even the update. SCN and online control module update are two completely different things. SCN stands for Software Calibration Number and changes the behavior of control modules as well as enables/disables them or certain functions within. It also tells the vehicle that a control module has been added, removed or exchanged. But without write access to VeDoc it’s pretty worthless to even considered paying for an account.
Thanks for the reply mate!
I know what SCN coding is. I know also that ONLINE programming is always followed by SCN coding. That is why I asked what is happen after the OFFLINE programming of a control module. For example if I perform an offline programming of a ME9.7 control unit, SCN coding will be not necessary? Will the car start?
Also, is it possible to force an older Star Diagnosis system, for example Windows XP with 11.2012 Star Diagnosis version, to use a newer SDFlash Release CD(11.2014) for programming update?
Best Regards
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017+2018 - thanh1974 - 03-29-2018
Best Regards
yes i know some one able can do this version and upto 2014.. but i am not have it yet... u can check some selling in here too if u able do it or get it let me know
