RE: Support thread for FullFixbySamik paid version - Sam!k - 08-19-2025
(08-19-2025, 10:09 PM)tirex2k Wrote: Only managed to get this version to work on a modded windows with firewall cut and some other tweaks. MSDN windows defender always complains on different files and deletes it considering them as a threat. To avoid most problems id advice using mostly cut windows and avoid installing any other software which might not be compatible with xdos
Don't agree!
Need clean original windows Pro without firewall ON.
Microsoft Definition can't delete any files, because all needed files automatically going to inclusion.
RE: Support thread for FullFixbySamik paid version - Allroad - 08-29-2025
(07-22-2025, 09:36 PM)Pi-Rho_216 Wrote: 1. Does it support Windows 11 Pro?
2. Does it support Windows 10/11 LTSC?
3. Do I understand it correctly that it contains/installs pretty much everything that's usually included in typical Xentry Acronis images like the ones from Linkov? Is anything missing other than EPC/WIS, which is trivial to install anyway?
4. Do I understand it correctly that there should be no issues with installing two copies of Windows on one laptop, one with Cars one with Trucks, only it will require paying for two keys?
Hi Yes it works onn WIn 10 LTSC.
I have always used Windoes 10 LTSC on all my laptops for years
RE: Support thread for FullFixbySamik paid version - vnogueira - 08-29-2025
Hi everyone - had a situation here .... fresh windows, fresh install and fresh fullfix , all good and done but it did not installed the sd - vci switcher... therefore, we restarted the pc and tried to run again the fix (done this before and solved the switcher problem) - but got this situation like you can see at the pic... how to solve that?     PC_HWID is wrong (but how? since I havent made anything at all - just restarted the pc)
RE: Support thread for FullFixbySamik paid version - Sam!k - 08-29-2025
(08-29-2025, 10:02 PM)vnogueira Wrote: Hi everyone - had a situation here .... fresh windows, fresh install and fresh fullfix , all good and done but it did not installed the sd - vci switcher... therefore, we restarted the pc and tried to run again the fix (done this before and solved the switcher problem) - but got this situation like you can see at the pic... how to solve that?     PC_HWID is wrong (but how? since I havent made anything at all - just restarted the pc)
PM to check
RE: Support thread for FullFixbySamik paid version - mohammad 09071 - 08-31-2025
hello mate
this activation key is not working , i get error " no internet connection " then " incorrect activation key "
RE: Support thread for FullFixbySamik paid version - Sam!k - 08-31-2025
(08-31-2025, 05:30 PM)mohammad 09071 Wrote: hello mate
Make sure you download latest version of Fix.
Make sure you have internet.
If have internet and didn't work, try some VPN.
yes i tried few times then it is done
i will test it now
thank you
RE: Support thread for FullFixbySamik paid version - mohammad 09071 - 09-01-2025
when i finished installing i cloned the drive to used it with a costumer laptop
here is the problem i could not activate xentry any more after cloning drive or swap ssd to an other laptop
and this is the most important to me as a seller to clone the disk
RE: Support thread for FullFixbySamik paid version - Rocinante - 09-01-2025
(09-01-2025, 12:06 AM)mohammad 09071 Wrote: when i finished installing i cloned the drive to used it with a costumer laptop
As a seller? You should be paying for each activation as Samik is a seller as well.. you are admitting to stealing his work  Headbang Fing20
I guess you're going to have to learn how to do it manually to "sell" your product
