RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017+2018 - Mackhack - 03-29-2018
Of course it will start after offline coding. I flashed several MSG of W211 and W203 offline over the years including my E55 AMG twice and never had any issues. And yes, you can use an old system with a newer flash data release. And no you don’t need SCN after Offline. It would defeat the purpose of offline coding.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017 - Tiqr - 04-01-2018
(12-02-2017, 08:46 PM)xzt Wrote: Hi, I was tested your file pesona on version 12.2017, and after few test not work , but I was find that are missing some file, I was search old dvd flash data,to work normaly you need folder FDOK,file etns,etnh,etnt,etc from version old 2012,2011,2010,2009,for pkw,transp,smart tested and work fine in simulation with real vin car !
keep good work,regards!
Hi
Can you upload #FDOK Folder from early version of xentry.
My xentry 07.2017. Or can you tell me where to download that folder.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017+2018 - pesona - 04-01-2018
@Tiqr look at the first post. there is a link to sdflash collections from 10-2008 up to 2017 in the bottom or you can try to download from my sample mini sdflash at the first post too.
i add the sample mini sdflash with PKW Fdok, Smart Fdok, and Transporter Fdok.
the Fdok folder's contents is complete fdok folder from 10-2008 up to 03-2018. Please look at the first post.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017+2018 - Tiqr - 04-01-2018
(04-01-2018, 07:04 PM)pesona Wrote: @Tiqr look at the first post. there is a link to sdflash collections from 10-2008 up to 2017 in the bottom or you can try to download from my mini sdflash at the first post too.
Thanks for fast response @pesona. I download and mount SDflash disk to drive.
Now i get this error.
here my information.
Windows 7 x86
Xentry 07/2017
i put all fix.
Thanks.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017+2018 - Tboz.jnr - 04-05-2018
Hi, I get this message when I hit control module programming on W906. Any help? Many thanks
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017+2018 - pesona - 04-05-2018
(04-05-2018, 02:29 PM)Tboz.jnr Wrote: Hi, I get this message when I hit control module programming on W906. Any help? Many thanks
hi,
if you don't want to run das from xentry, at least, run das, after that run xentry. let xentry standby in the background.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017+2018 - Mackhack - 04-05-2018
Comes from the standalone DAS. If you run DAS through Xentry, you won’t see that error message.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017+2018 - tsimplas007 - 04-06-2018
Why do we need SDFlash releases from 2015(for PKW updating) and above when there are no ent * files inside them?
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017+2018 - pesona - 04-06-2018
@tsimplas007 from a question like this (it is like a good feedback for an idea), somehow, there will be a good selfless samaritan, taking his precious time to check the *.cff, "create/copy" etn*.* for it, to be used by others for work or hobby or research, free and no string attach.
