RE: Support thread for FullFixbySamik paid version - palco2 - 09-07-2025 Hello, Sam!k. A question? I don't want to mess the things up. Two days ago I have installed 8.3.2 fix. But I still did not applied the key. Can I install 8.3.3 version today as I can see it is already released, or it will screw the things up? RE: Support thread for FullFixbySamik paid version - Sam!k - 09-07-2025 (09-07-2025, 10:20 AM)palco2 Wrote: Hello, Sam!k. Updated only SW Finder and DAS Special functions, select only this two options! RE: Support thread for FullFixbySamik paid version - empetry - 09-09-2025 You don't need to learn all languages. My translator is the one who translates automatically. "Hi, I installed the truck, but I'm getting this error. Can you fix it, or is there a future fix planned? I've included the procedure. I use this to change the power. I used the latest version of the fix." RE: Support thread for FullFixbySamik paid version - RepairDone - 09-10-2025 I successfully installed everything and its works with my C4 Interface. Xentry XDOS 25.9.4 Now I want to use it with my scanmatic 3 pro as well. How can I setup this? I would like to switch between my C4 and the Scanmatic 3 RE: Support thread for FullFixbySamik paid version - Alex123222 - 09-10-2025 (09-10-2025, 05:53 PM)RepairDone Wrote: I successfully installed everything and its works with my C4 Interface. Need to create another boot (Windows) with installed Xentry PassThru version or on another laptop . Can't have OpenShell (for C4) and PassThru (for scanmatic) on same Windows unless its not on Virtual machine RE: Support thread for FullFixbySamik paid version - RepairDone - 09-10-2025 Thanks for the info! So if I want to use my Scanmatic 3 Pro as well, I’d need a separate Windows Xentry PassThru, right? Doe this FullFix work as well without buying a other license because its the same Laptop? Do I get any real advantages when using the Scanmatic 3 Pro compared to my SDconnect C4 — for example faster connection, better compatibility (For newer cars for example), or additional functions? Or is it basically the same, just another interface option? RE: Support thread for FullFixbySamik paid version - websun - 09-12-2025 Hello zenzefi certificate seems unavailable after installing the paid fix. On top of that I cannot import the 26.11 certificate that has been circulating: File: "After-Sales_STANDARD_2025.11.26.p12" Failure: Backend not found which could have issued the certificate with subject key: 65-6A-8D-DF-9D-D3-F9-32-7E-D8-56-DA-51-2D-7A-40-4E-3C-75-5C. RE: Support thread for FullFixbySamik paid version - Sam!k - 09-12-2025 (09-12-2025, 06:38 PM)websun Wrote: Hello zenzefi certificate seems unavailable after installing the paid fix. You install it wrong! Run fix one more time, select only install certificate option and read what says program! RE: Support thread for FullFixbySamik paid version - websun - 09-12-2025 Will do, I did follow the steps initially. Yes sorted sorry needed a reboot before thanks all working for me except wis/asra which is just an update kit on a full install
