RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017+2018 - martininkent - 06-15-2018
REALLY OH OK IL LOOK AGAIN
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017+2018 - martininkent - 06-18-2018
can anyone shed some light on this, is it just the fact the ecu is not needing the ecu update ?
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017+2018 - audiomeca - 06-18-2018
Easy.
the TCU model fitted is not ok for this car, and xentry not can calculate the right latest software for this car. this car not sold any time with this TCU model fitted!!!, need update manual with vediamo or by external tool
regards
hi audiomeca,
well i have looked at the build sheet at looker smarts for this car vin number and its the right ecu part number ? so its never been changed,
(06-18-2018, 01:53 PM)audiomeca Wrote: Easy.
regards
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017+2018 - audiomeca - 06-19-2018
need vin number and tcu model fitted
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017+2018 - kwork - 07-03-2018
Can I offline flash update for some ECU for facelift 204049?
nothing in 204 for DAS standalone menu.
can not flash for facelift model?
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017+2018 - pesona - 07-03-2018
@kwork
the 204 bm can be expanded by adding model(s) that is not covered yet but it is not as good as the original listed.
Vediamo is the way to go.
just my .02 cents
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017+2018 - alexjx - 07-21-2018
hello
does this work with xdos 07/18?
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017+2018 - pesona - 07-21-2018
@alexjx please try and give feedback. btw, don't replace the original but use batch file to switch original and offline.
