[Solved] C3 is not connecting with W204 - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: [Solved] C3 is not connecting with W204 (/Thread-Solved-C3-is-not-connecting-with-W204) |
RE: C3 is not connecting with W204 - SmartM - 10-12-2016 (10-12-2016, 08:15 PM)Decodec Wrote:(10-12-2016, 03:20 PM)SmartM Wrote: Hello Decodec, Yes, you can rename, but recommend laco210, first save the original files, because I had a problem with C4 RE: C3 is not connecting with W204 - Decodec - 10-14-2016 (10-10-2016, 01:30 PM)laco210 Wrote: First try in toolkit.ini delete line skipcomports=all and set line usecomport=2 then you will see in SDconnect toolkit PartD on display after mux connection. The winner of the topic issss... laco210 !!! Your solution work perfectly! Everything is working like a charm now I have Xentry 09/2015 (I made mistake in 1st post - I wrote 07/2015). Problem solved. Thanks and reputation for you ![]() ![]()
