Permanent DTC P0562 - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: Permanent DTC P0562 (/Thread-Permanent-DTC-P0562) |
RE: Permanent DTC P0562 - kino0924 - 11-19-2016 Finally I had chance to hook it up with Xentry Here is actual log from Xentry Thanks, RE: Permanent DTC P0562 - Rocinante - 11-21-2016 Your circuit 87 fuse is blown.. RE: Permanent DTC P0562 - kino0924 - 11-21-2016 (11-21-2016, 01:06 AM)Rocinante Wrote: Your circuit 87 fuse is blown.. Thank you for reply. May I ask where is circuit 87 fuse?? When I check fuse box, it goes only till 72. Also I cant find any information about 'circuit 87 fuse' Thanks, RE: Permanent DTC P0562 - Rocinante - 11-22-2016 As far as I can tell, its a 15amp fuse in F55/5 fuse number 43 Once you find the blown or missing fuse, you need to figure out which component is blowing it or if the wiring is shorted to ground.. Circuit 87 is not a fuse number its the designation for the circuit that the ME computer turns on via a relay.. RE: Permanent DTC P0562 - kino0924 - 11-22-2016 (11-22-2016, 01:05 AM)Rocinante Wrote: As far as I can tell, its a 15amp fuse in F55/5 fuse number 43 Thank you for your reply but the fuse seems to be normal. I see Fuse 43 in F55/5 is 15amp and looks totally normal. I also tested with multi meter and it tells that the fuse is totally fine. Can it be relay fault near SAM? RE: Permanent DTC P0562 - kino0924 - 11-22-2016 !!!!!!!!! the stupid shit problem has been solved. Based on Rocinante's comment, I searched WIS and found F55/5 bank is fuse 37 to 45 And I found broken fuse on 44 I am so stupid that I did not check fuse from the beginning. The stupid issue bothered me for 2month and its finally over. Thank you for all who helped me. RE: Permanent DTC P0562 - kino0924 - 01-17-2017 Now, I am having another problem. Fuse 44 is keep blowing up. What kind of component/part that can burn fuse 44? RE: Permanent DTC P0562 - Raints - 01-17-2017 First disconnect Engine and AC electric suction fan with integrated control. Check Z7/36 connector sleeve. and i attache wiring diagram and location of sleeve. RE: Permanent DTC P0562 - kino0924 - 01-18-2017 Thank you Raints for posting diagram. There was no wiring issue or any repair/crash before this happens. So I believe wiring it self is totally fine. Also, the diagram tells me that Fuse 44 connected to K100 KL relay. I am going to test if relay is good or not. Thanks. |
