SD Connect & 09.2016 Problem Firmware & DAS Error - Printable Version
+---- Thread: SD Connect & 09.2016 Problem Firmware & DAS Error (/Thread-SD-Connect-09-2016-Problem-Firmware-DAS-Error)
Pages: 1 2 3 4
RE: SD Connect & 09.2016 Problem Firmware & DAS Error - Anturage - 11-09-2016
Which software corrupted?
Only Toolkit used while testing.
If selftest file is corrupted it will not start in SDConnect.
Checksum will fail.
If firmware is corrupted SDConnect will show you picture with Compact4 connected and will not start.
RE: SD Connect & 09.2016 Problem Firmware & DAS Error - Marcos - 11-09-2016
(11-09-2016, 04:21 AM)Anturage Wrote: Which software corrupted?
Checksum will fail.
I'm not talking about the toolkit selftest corrupted.
Firmware files inside the mux itself can be corrupted during an update.
I wonder how many genuine muxes had suffered from the same failures. All of them are trashed?
I remember a reply from a guy who's mainly working with genuine stuff and was so disappointed about their quality.
EDITED AFTER READING YOUR EDITED REPLY Smile
"If firmware is corrupted SDConnect will show you picture with Compact4 connected and will not start."
If this will happen what must be done to revive the mux?
If firmware corrupted before downloading it will not be installed - bad CRC.
If firmware corrupted after unit will refuse boot up or will show zero in FW version.
No any problems with original units.
More then 100 items where in my hands.
(11-09-2016, 04:28 AM)Marcos Wrote: "If firmware is corrupted SDConnect will show you picture with Compact4 connected and will not start."
Do what is pictured. Connect, startup Toolkit, click only item you will see in FW update window.
(11-09-2016, 04:33 AM)Anturage Wrote: If firmware corrupted before downloading it will not be installed - bad CRC.
Perfect. I got that.
And if you try to do that an error pops up that the mux can not be seen or connected to be upgraded. What's next Smile...Trash? Smile
(11-09-2016, 04:40 AM)Marcos Wrote: What's next Smile...Trash? Smile
In case original sent to suppler.
In case china trash.
I know you are an experienced guy about these tools.
Based on these facts do you consider this a hardware or software failure?
Hardware 200%
(11-09-2016, 04:52 AM)Anturage Wrote: Hardware 200%
Thanks buddy. Can we blame a specific IC or hardware device inside the mux or can be multiple causes for this?
Anything. From fake IC to low quality PCB and soldering.
In china unit any part inside could be wrong type, fatly or fake.
Only RAMtest fail is easy to fix. Other cases are not so clear.
