RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017+2018 - pmercury - 01-19-2019
Hi !
thx for all your great work
I use to use 2017-05 alcohol 120% mounted, because ithought the size is big so has all ....
you say " I use self-made sdflash (combine 10-2008 up to 03-2018 sdflash)"
do you have a download for that combined sdflash ?
if not, how to combine ?
and where to put the whole files ?
thx !
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017+2018 - Marcos - 01-20-2019
(01-19-2019, 03:53 PM)pmercury Wrote: do you have a download for that combined sdflash ?
First post, at the end of that, you'll find a torrent for this "combined sdflash". Haven't checked if still seeded.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017+2018 - martininkent - 02-24-2019
hi how do i get das to offer me online networked or off line network
i have down load the fix flshen and followed the guide (smart one ) but it still dont give me the option in das , it it does not pick up the files i have sd collection or on my usb ( iso )
any help is welcom thanks
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017+2018 - ziwon0 - 02-27-2019
hello
does this work with xdos 03/19?
What should I change  if work?
change das.ini date?
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017+2018 - pesona - 02-27-2019
it should work with xdos 2019/03.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017+2018 - ziwon0 - 02-28-2019
(02-27-2019, 09:05 PM)pesona Wrote: it should work with xdos 2019/03.
# 1 was as described
Offline does not work What's wrong?
What should I do?
I want help
THANK YOU
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017+2018 - Mackhack - 02-28-2019
What should I do?
I want help
THANK YOU
Don’t use the sim  049 653 Cheer2
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017+2018 - konokhk - 02-28-2019
When offline encoding is performed, does the das search for the desired cff file on the CD?
What should I do?
I want help
THANK YOU
thank you
2019.03 it ok
yes it work
thank you
