RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017+2018 - Mackhack - 04-19-2019
3.2019. comparing the files shows there is not really anything that has changed since.
DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017+2018 - gstardiag - 04-19-2019
(04-19-2019, 01:13 AM)Mackhack Wrote: 3.2019. comparing the files shows there is not really anything that has changed since.
I mean Oldest xentrySmile not newest)
And thank you for response!
With older versions you have to use older fixes for this. I’m not sure if pesona still have them up for download. Back then these files were essential and with each version MB released many of them changed from version to version. At least that is my observation. Once XDOS came out the files responsible for offline coding didn’t change as often anymore since Daimler cares less about old cars. They focus on new cars and that Xentry gets daily Addon updates now.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017+2018 - 190-Sportline - 06-25-2019
The Torrent is death, can you reupload? I have the version 05\19
Can you reupload? I have Version 05\19
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2019 - temo4ka - 07-05-2019
Hello, specialists.
Yesterday, I finally managed to get the w639 offline programming working.
I did the following, as was written earlier:
1) Changed the date in SDFlash / Release / Transp / Profi_CD.ini to 03/2018;
2) [DASDataVersion] to 03/2018;
3) Copy Flashen folder and SDFlash / Release / Transp / Flashen / Ini / inbettrieb.ini from this topic
I have DAS from XDOS 05/2019.
And I have some questions:
1) For example, I want to upgrade the automatic transmission on the 639. CAR produced in 2009. Should I take turns inserting SDFlashDVD images into my virtual drive since 2009 by turns, until I reach the last one, 2018? What are the options for automating the process?
2) If I need to update the unit in the car for example, 2010 production, and I will use SDFlashDVD 2011, every time I need to change the [DASDataVersion] of das and copy the Profi_cd.ini?
What can you recommend?
thx
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2019 - vahid-miralizadeh - 07-16-2019
i read first post but my problem not solved
Release code issue
please help
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2019 - Rocinante - 07-16-2019
(07-16-2019, 02:19 AM)vahid-miralizadeh Wrote: i read first post but my problem not solved
Release code issue
please help
That is coding.. there is no offline coding.. just offline software updates..
no the solution is In programming
(07-16-2019, 08:20 PM)vahid-miralizadeh Wrote: no the solution is In programming
I'm not arguing with you.. I'm telling you..
Look at the stickied thread for trans offline coding..
