RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2019 - momosam - 08-27-2019 (08-27-2019, 06:16 PM)kashalot Wrote: At this point, I stopped too, but what I have read here you can perform the SCN coding with Vediamo.There is also a key generator that calculates the SCN codiertstring, but it is not free.Have you activated offline programming? RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2019 - kashalot - 08-28-2019 However programming will still require SCN coding after programming. RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2019 - bayramserik - 08-29-2019 Hello. before writing I have done all the options suggested in this thread. there was a problem. when programming offline programming is suddenly interrupted and begins to repeat programming from the beginning but without success. what am I doing wrong or what have I installed wrong? please help me. RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2019 - momosam - 08-29-2019 (08-29-2019, 05:53 PM)bayramserik Wrote: Hello. before writing I have done all the options suggested in this thread. there was a problem. when programming offline programming is suddenly interrupted and begins to repeat programming from the beginning but without success. what am I doing wrong or what have I installed wrong? please help me.FLASH IT WITH VEDIAMO RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2019 - pesona - 08-29-2019 (08-29-2019, 05:53 PM)bayramserik Wrote: Hello. before writing I have done all the options suggested in this thread. there was a problem. when programming offline programming is suddenly interrupted and begins to repeat programming from the beginning but without success. what am I doing wrong or what have I installed wrong? please help me.your das version is 2013-01. this thread doesn't cover it because that release offlne needs only replace inbetrieb.ini i am not a practitioner of this, cmiiw, you get das cal error 11.913.20010 (picture no 6). possibly near bottom power voltage. either you can charge the battery first or use external power. RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2019 - bayramserik - 08-29-2019 I used 2 different versions of DAS. 01.2013 and 12.2017. same result. first asked to enter a verification number in the post 285 (screenshot attached). then I installed it on both versions of the DAS your file which you have provided *EGS2 NoOfflineSeed.rar*. after replacing this file, it turned out what I wrote above. Could it be that the problem is in the file? RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2019 - pesona - 08-30-2019 (08-29-2019, 08:29 PM)bayramserik Wrote: I used 2 different versions of DAS. 01.2013 and 12.2017. same result. first asked to enter a verification number in the post 285 (screenshot attached). then I installed it on both versions of the DAS your file which you have provided *EGS2 NoOfflineSeed.rar*. after replacing this file, it turned out what I wrote above. Could it be that the problem is in the file? aha, so you get das cal error 11.913.20010 because of trying to avoid the "release code" using *EGS2 NoOfflineSeed.rar*, don't you? i guess, ecu refused to go on (to be flashed) because of no release code. if this is the case, cmiiw, using vediamo, ecu needs seedkey too. from what you have done, your logic is good mate. ![]() would you upload your log files using standard egs2 cbf when das asks release code and also please press F11 and choose hotline and upload it too? RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2019 - bayramserik - 08-30-2019 who will be able to share the original file EGS2.cnt? I replaced mine without making a copy of the original. what do you think, what will happen if you replace the file EGS2.cnt from DAS 2008, or from the version that does not require you to enter the code? if you have one, can you share it with us? RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2019 - pesona - 08-30-2019 (08-30-2019, 08:45 AM)bayramserik Wrote: who will be able to share the original file EGS2.cnt? I replaced mine without making a copy of the originalsure, here is the original with mandatory seedkey and release code for your version [attachment=320540] (08-30-2019, 08:45 AM)bayramserik Wrote: what do you think, what will happen if you replace the file EGS2.cnt from DAS 2008, or from the version that does not require you to enter the code? if you have one, can you share it with us? there is no bad thing with doing research and learning. it always feels good. [attachment=320539] btw, with the previous file "EGS2 NoOfflineSeed.rar", it is already bypass the required (mandatory) seedkey and release code from latest egr2.cnt. here is the text, i copy from your log above: 2019-08-29 16:01:52: Number of max flashretry(I_FLASHRETRY) = 5 2019-08-29 16:01:53: Init before flashing processed ; Ret=0; Detail: 2019-08-29 16:01:53: Check:I_K_FLASH_SEED_KEY(i_SeedKey; Result=1 (OK >= 0) 2019-08-29 16:01:55: FM_DoFlash(CAL_DoFlash: EGS2,|0034487510_001); Ret=0 2019-08-29 16:01:57: FlashTime = 0:5 minutes (estimated time: 8 minutes) 2019-08-29 16:01 Battery voltage = 11.42019-08-29 16:01 FM_DoFlash(S_FLASHPROCESS); Ret=NOK2019-08-29 16:01 Check1:ResultOfCALDOFlash=0 ; DetailedError='11.913.20010' (DAS.CAL.CAESAR)2019-08-29 16:01 Check2 not necessary since flashing not successfull2019-08-29 16:01:59: EGS2: SG-Reset proceeded 2019-08-29 16:01:59: Check3:I_K_FLASH_RESET(i_ansprechbar_nach_reset)1 (OK >= 0) 2019-08-29 16:02:00: Check4:InitECU not necessary, because Reset and Init was OK imho, from the log above, there are several important notes. Init before flashing processed ; Ret=0; Detail: OK Seed_key : OK Do_Flash : already instructed by DAS Do_Flash result : NOK Reset : OK if you can, please upload log file and F11 print hotline from egr2.cnt with mandatory seedkey and release code. |
