RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2019 - bayramserik - 08-30-2019
I checked both files. the first archive file 2_CNT_RU 2017-12 ETC. the second archive file ETC 2_CNT_RU 2008-10. on the first and second file errors are awarded. your opinion?
who can share das xentry 2010 installation discs? can't find them online
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2019 - pesona - 08-30-2019
hi the old one is full of errors while the new one, even with error, das arrived at check 1 and check 2 release code but it is a pity without the log file.
but thanks anyway for your efforts.
Reps + thanks are send to you
I have this car will be another 2-4 days. if you have any solutions we can check on this car. it will be good for everyone. if there are any options, then ask everyone to suggest solutions. I hope we can solve this problem.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2019 - kashalot - 08-31-2019
If it helps I could only find THE XENTRY 2010 as a VM.
[attachment=320662]
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2019 - Johnplus - 09-01-2019
I tried the all in one package for offline programming in 09-2019, but there is an error. see attachment.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2019 - Mackhack - 09-02-2019
(09-01-2019, 05:24 PM)Johnplus Wrote: I tried the all in one package for offline programming in 09-2019, but there is an error. see attachment.
Because you tried to do SCN coding in simulation mode. It never works in sim or with cracked DAS Standalone.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2019 - thanh1974 - 09-03-2019
will read me more later goody stuff
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2019 - Johnplus - 09-06-2019
Something changed in 9-2019. Version 07-2019 was working fine with the same setup. It happen on real car too.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2019 - pesona - 09-13-2019
(09-06-2019, 11:41 PM)Johnplus Wrote: Something changed in 9-2019. Version 07-2019 was working fine with the same setup. It happen on real car too.
today, i try in simulation and indeed in 2019-09, xentry cobradbl is down that's why das gets error when asking some vehicle's data from xentry.
either xentry dbl files are deleted intentionally by daimler or it will be fixed by addons, it is no problem.
i have fixed it.
but probably, it is a sign to move on to vediamo/dts.
