RE: Support thread for FullFixbySamik paid version - Sam!k - 10-29-2025
(10-29-2025, 11:06 PM)billydv Wrote: Hi Samik, I purchased another activation key because I wanted to install on another system. Worked perfectly but when I go to a newer car, yellow After sales cert ribbon not showing up
So your problem is yellow ribbon or you can't diagnose new car?
You don't need that yellow ribbon, i think you need connect and diagnose car, right?
So write your real problem and give more information:
If you see any errors, show them
Which version of Xentry do you use
Which adapter do you use
And which new car you want connect.
RE: Support thread for FullFixbySamik paid version - billydv - 10-29-2025
When I installed 8.3.7 on my laptop and diagnosed car, a yellow ribbon appeared. This 8.3.8 it didn't. I will connect car tomorrow and report back
RE: Support thread for FullFixbySamik paid version - Sam!k - 11-01-2025
(10-29-2025, 11:43 PM)billydv Wrote: When I installed 8.3.7 on my laptop and diagnosed car, a yellow ribbon appeared. This 8.3.8 it didn't. I will connect car tomorrow and report back
As you didn't write i think everythink is ok but if not, just download latest version and select only install certificates option.
RE: Support thread for FullFixbySamik paid version - billydv - 11-01-2025
After actually connecting vehicle, all worked as it should
RE: Support thread for FullFixbySamik paid version - jeermy - 11-03-2025
By this fix can use original Xentry VCI with Daimler Truck 2025 Normally ?
RE: Support thread for FullFixbySamik paid version - Sam!k - 11-04-2025
(11-03-2025, 11:58 PM)jeermy Wrote: By this fix can use original Xentry VCI with Daimler Truck 2025 Normally ?
Fix doesn't do in that part anything.
If your oti VCI working with Daimler Truck, then it will work, if doesn't, then won't work.
RE: Support thread for FullFixbySamik paid version - jeermy - 11-09-2025
Ok
What is the best version of Xentry that can be used with the original Xentry VCI to get full support by using it with your FullFixbySamik?
RE: Support thread for FullFixbySamik paid version - Sam!k - 11-09-2025
(11-09-2025, 12:44 AM)jeermy Wrote: Ok
It's depends from your clients)
RE: Support thread for FullFixbySamik paid version - Wizen - 11-12-2025
dell pls
