RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2019 - 0868713877 - 01-14-2020
please help: i installed das programming offline and downloaded sdflash but i don't know how to make it work and use it.
Please someone help me, thanks
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017+2018 - blueabyss - 02-19-2020
(03-21-2018, 06:35 PM)pesona Wrote: This is new.
- i made for myself, a utility. I call it Flash finder.
i enter "MB Object Number" and i will get all CFF and or all SMR-F+*RL that are available including the location of those files.
and vice versa
if i enter CFF or SMR-F, i will get the MB Object-Number. (*SMR-F has a long way to go. Daimler laughs at me (and to you too))
I think, i will improve it by adding Baumuster/Baureihe in the entry option if i have to.
Because one MB Object Number, gives result for all CFF/SMR-F+*RL for all Baumuster/Baureihe.
It is interesting for me. It is a good reference to for Vediamo or DTS newbie.
It helps me to know if an ecu has an optional new update or not. (newbie indeed, )
Thank you for your work - "Flash finder" is available somewhere
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2019 - الزعبي1 - 03-11-2020
(12-29-2019, 10:36 AM)0868713877 Wrote: I have xentry12 / 2019 whether Das programming offline installation is suitable please someone help me
I'm searching for xentry DAS 12/2019 offline coding , still nothing yet.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2019 - Benzdriver23 - 03-25-2020
Hi, I have a problem with my C4 in DAS. Xentry works perfect (5.2018) but with DAS can't Initialize the C4 and can't connect to cars. Anybody an idea to fix it?
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2019 - thehung194 - 04-05-2020
(07-26-2016, 05:10 PM)pesona Wrote: 1.PKW Offline Programming, SCN Offline Coding & Offline Entry for Retrofits & Modifications
Software: Xentry XP, XDOS(32/64)
Release: 2015 - 03/2018.
How to:
1. Rename original "Flashen" folder in: das\trees\pkw to "FlashenORI"
2. Extract and copy the offline flashen
So in the das\trees\pkw you have two folders:
Flashen : for offline programming
FlashenORI : original folder. in case you need to use for online programming
Make a simple batch file to have a menu to choose “OFFLINE” AND “ORIGINAL” to switch between these folders.
It is better including changing the name of Flashen folders in SMART & Transporter too.
ver 2.0:
What's new in ver 2.0:
- Enable DAS online/offline Entry for Retrofits & Modifications
ver 1.01
What's new in ver 1.01
- Full flashen folder
- add 204.041
notes:
- for some xdos release, there is no akttab.csv in the PKW sdflash folder
here it is:
2. SMART Offline Programming
Requirement: Need Offline Programming PKW installed
how to:
1. Rename SMART Flashen folder in:
DAS\Trees\Smart\Flashen to FlashenORI
2. Extract and copy the offline flashen DAS\Trees\Smart
So in the das\trees\Smart you have two folders:
here it is version 1.0:
3. TRANSPORTER/VAN Offline Programming
how to:
1. Rename TRANSP Flashen folder in:
DAS\Trees\Transp\Flashen to FlashenORI
2. Extract and copy the offline flashen to DAS\Trees\Transp
so you have 2 folders.
It is better including changing the name of Flashen folders in ALL (PKW, SMART, TRANSP).
here it is version 1.0: (q.e.d. proven here)
4. MENU
This is example of menu file that you can use to choose Offline or Original.
Compatible with: WINXP and latest OS
For: Xentry XP, XDOS 32bit, XDOS 64bit
Version: 1.1 (Include PKW, SMART, TRANSPORTER/VAN)
What's new in ver 1.1:
- copy to desktop. it will know what OS, and 32/64 bit automatically
if the menu above is failed on your OS, here is the source file that you can adjust or delete the determination of OS.
5. PKW & SMART Offline programming for XENTRY XP
Software: Xentry XP
Release: 2014
Feature: Full Flashen folder + how to
How to: (1.01)
1. Rename original flashen folder in: das\trees\pkw to e.g: flashenORI
6. Transporter Offline programming for XENTRY XP
Software: Xentry XP
Release: 2014
How to: (1.0)
1. Rename original flashen folder in: das\trees\transp to e.g: flashenORI
TRANSPORTER/VAN AKTTAB.CSV
here is replacement for missing "akttab.csv" in Transporter e.g 12-2015, 09-2016 version etc
7. Transporter INBETRIEB.INI V2 Released in 03-2017 for All DAS Version :
what's new:
1. it covers ALL Transporter vehicles in DAS (from 4 transp type to 16 transp type)
2. it will recognize sdflash in virtual drive
how-to:
- extract & replace the inbetrieb.ini of the "offline Flashen" in:
DAS\trees\Transp\Flashen\ini\
here it is:
8. CD SDFlash Mini 2.0
If your sdflash in harddrive is not good/complete/missing a file(s), DAS will try to look for SDFlash CD. Fix that sdflash or Mount this sample CD SDFlash Mini in virtual drive when doing offline programming.
what's new ver 2.0:
- add FDOK folder from SDFLASH 10-2008 up to 03-2018 (PKW, SMART,TRANSP)
Disclaimer:
for official and educational use only. If you use them for any illegal purposes (such as programming stolen car/smart/van), this is your own responsibility. i'm definitely against it.
EDIT:
Tips & Tricks
Quote:I have tested Offline Programming with xdos 03-2018 myself in real diagnostic. I use self-made sdflash (combine 10-2008 up to 03-2018 sdflash) and standard sdflash 07-2014 (i choose because it still has many etn* inside)
here are some pictures:
PKW:
ETC update with self-made sdflash up to 03-2018. Sdflash is copy to harddrive:
ETC
ME update with SDFLASH iso 07-2014:
ME
SMART:
Simulation with real vin
Transporter:
CDID2 (offers 3 software update from self-made sdflash)
Quote:DAS only allows max 3 new firmware in one sdflash.
if your self-made sdflash has more than 3 new software, DAS will warn: "sdflash contents has xxx new updates. Contact help desk. Click ok or cancel".
if you click ok, DAS will not update and inform you that there is no newer software update.
for xentry version 2017-12, here is good information from xzt in post 188:.
(12-02-2017, 08:46 PM)xzt Wrote: Hi, I was tested your file pesona on version 12.2017, and after few test not work , but I was find that are missing some file, I was search old dvd flash data,to work normaly you need folder FDOK,file etns,etnh,etnt,etc from version old 2012,2011,2010,2009,for pkw,transp,smart tested and work fine in simulation with real vin car !
keep good work,regards!
Q:
(02-09-2018, 08:04 PM)megacrazy Wrote: Thanks for putting work into this pesona.
Unfortunately I am having issues with programming Comand. I'm running into the same issue other people had, namely "Insert DVD Labeled Star Diagnostic" after going to "Offline Programming" and advancing through the first prompt.
Here's some info:
- I'm running 2016.5 off a Dell laptop, Windows 7
- "Offline" programming shows up after replacing the "Flashen" folder
- SDFlash.ini has correct links to the appropriate folders
- I have downloaded various ISOs from the SDFlash collection and mounted them, no change
- The Inbetrieb.ini file seems to have the correct paths, I've even added new ones after mounting the ISOs under different drive letters, no change
- Replaced the entire "Release" folder with one from the correct ISO. The one I had was slightly less files...still no change.
- The system doesn't seem to check the CD drive at all. I have a firmware cd in there and it doesn't even start spinning.
Any ideas on what to try next? Thanks!
A:
(02-10-2018, 09:10 PM)megacrazy Wrote: So i figured this out. For some reason as soon as I changed my DAS.inf version/date to match the flash data date it started working. The next issue was missing #FDOK folder which I copy/pasted. Everything worked after that.
(02-11-2018, 12:22 AM)megacrazy Wrote: I copied the entire 2016.5 release folder to SDFlash\Release. The "profi_cd.ini" file in that folder had "DAS-CD-NR=05/2016"
[DasDataVersion] in Das.inf was set to 2014 even though the "official" version I have is 05/2016. I changed that date to 05/2016
Basically as long as those 2 dates matched (in das.inf and profi_cd.ini) it wouldn't ask for the Star CD anymore and it would go to the next step of the flashing process, displaying flash data that was available. It also detected any ISOs I mounted, regardless where they were mounted from (same drive/usb etc.)
Another links:
SDFLASH-Collections
SDFlash Collection 2008-2017 (torrent)
[url=http://mhhauto.com/Thread-SDFlash-Collection-2008-2017-torrent][/url]
So rewarding
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2019 - Mafioso - 04-11-2020
Does it will work on a Xentry PASSTHRU 05.2018?
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2019 - pesona - 04-11-2020
yes, as long as it is not a k-line ecu. use my xdpt das utility to make sure ignition on and off is available when you do ecu offline programming.
Can I just edit the "global.sim" file, for on/off ignition, is that will be enough?
yes, it is another method to turn on and off of das pt ignition.
