RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2019 - andros87 - 05-03-2020 hello i tried all these and i have this message No newer control module software was found what can i do for this ? is w211 model RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2019 - mahdyonline - 05-07-2020 for 2020.03 i can't work with that RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2019 - pesona - 05-07-2020 i will upload das offline 2019-09up this weekend. i gave to several members and got feedback that it works up to 2020.03. RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2019 - davidcie - 05-11-2020 Forgive my ignorance if this is obvious but... I would need this to enable offline coding of some W166 control modules. Looking at the INI files (eg. inbetrieb.ini) in the Flashen folder, I can see older models (like W164 I worked on before) but no mention of W166. Does this mod enable offline coding for newer models as well or do we still need DTS for that? RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2019 - ahadi - 05-12-2020 -------------- RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2019 - pesona - 05-12-2020 @davidcie this thread is for das vehicles. for a xentry vehicle, you need xentry with offline programming capabilities (who have ), vediamo or dts monaco.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2019 - davidcie - 05-12-2020 (05-12-2020, 05:14 AM)pesona Wrote: @davidcieThank you for some clarification! Since PKW = Personenkraftwagen = passenger cars, I thought it would cover all vehicles. It does not help that Xentry is often called "Xentry DAS"... aa, so complicated for a novice user / hobbyist But I guess you mean that for some (presumably older) cars, Xentry will actually launch DAS when you go into diagnosis (and these would be "DAS vehicles"), while for newer cars it will show menus inside Xentry itself ("Xentry vehicles")? I googled "Xentry vehicles" and "DAS vehicles" but have not found a list which vehicle is which category unfortunately Do you know of one? Am I correct to assume a comprehensive list of DAS vehicles is inside inbetrieb.ini (attached)?
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2019 - pesona - 05-12-2020 (05-12-2020, 01:28 PM)davidcie Wrote: Thank you for some clarification! Since PKW = Personenkraftwagen = passenger cars, I thought it would cover all vehicles. It does not help that Xentry is often called "Xentry DAS"... aa, so complicated for a novice user / hobbyistyou are correct, mate. you can use das standalone and look there what vehicles are there. i ever did the hard way by clicking every pictures in xentry to check what i needed to add in inbetrieb.ini to make every das variant vehicles are covered including w204. i hope my answer is good enough. my head is still spinning after a whole day trying all xentry advance license option. best regards RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - pesona - 05-13-2020 What's new: May 13, 2020
