RE: Support thread for FullFixbySamik paid version - rasli98 - 11-26-2025 Hello, I find an issue with version 8.3.9 and Xentry 09/2024. When I changed the xentry login to ''automatic'' I cant exit xentry. Only ctrl alt delete works. When xentry need login and password it's fine. Have a nice day
RE: Support thread for FullFixbySamik paid version - avandgarde - 11-26-2025 (11-26-2025, 11:24 PM)rasli98 Wrote: Hello, I find an issue with version 8.3.9 and Xentry 09/2024. When I changed the xentry login to ''automatic'' I cant exit xentry. Only ctrl alt delete works. When xentry need login and password it's fine. Have a nice day This is nothing new. It's normal. RE: Support thread for FullFixbySamik paid version - Qualified5098 - 12-01-2025 I’ve installed the 09/2025 version of Xentry together with the Samik solution, but I’m running into one issue. This weekend I tried diagnosing an SLK R170 from 1997. DAS only gives me access to the basic modules, and for modules like the engine ECU it requires HHTWIN. HHTWIN launches but then freezes and becomes completely unresponsive. Is there a known fix or workaround for this? RE: Support thread for FullFixbySamik paid version - Sam!k - 12-01-2025 (12-01-2025, 02:40 PM)Qualified5098 Wrote: I’ve installed the 09/2025 version of Xentry together with the Samik solution, but I’m running into one issue. This weekend I tried diagnosing an SLK R170 from 1997. DAS only gives me access to the basic modules, and for modules like the engine ECU it requires HHTWIN. HHTWIN launches but then freezes and becomes completely unresponsive. HHTWin in the fix is tracked from this forum, i didn't changed anything exactly in HHTWin. But usually it's working without any problems. What if you tun it in standalone mode from desktop? RE: Support thread for FullFixbySamik paid version - Qualified5098 - 12-01-2025 (12-01-2025, 03:44 PM)Sam!k Wrote:(12-01-2025, 02:40 PM)Qualified5098 Wrote: I’ve installed the 09/2025 version of Xentry together with the Samik solution, but I’m running into one issue. This weekend I tried diagnosing an SLK R170 from 1997. DAS only gives me access to the basic modules, and for modules like the engine ECU it requires HHTWIN. HHTWIN launches but then freezes and becomes completely unresponsive. The outcome is the same whether it’s accessed directly or from within Xentry. It remains stuck in the “initialized” status, and in TKAdministration I can see that no active session is present at that moment. Using an OEM SDConnect, no chinesium. Do i need to config another ini file for using the SDConnect? [attachment=722592] RE: Support thread for FullFixbySamik paid version - Sam!k - 12-02-2025 No need config anything else. Just check firewall, probobly he blocking connection. If it's disabled, enable and restore settings to default. RE: Support thread for FullFixbySamik paid version - empetry - 12-02-2025 Hi, I installed version 04/25 of the truck but the Euro 6 vehicles aren't showing up. Where did I go wrong? A friend of mine said that only version 10/24 shows and connects. Is this information correct? Can you tell me which version is the best and most functional? RE: Support thread for FullFixbySamik paid version - Qualified5098 - 12-03-2025 (12-02-2025, 01:51 AM)Sam!k Wrote: No need config anything else. There's no firewall, because it's completely disabled and no internet as well because i only use this airgapped, Windows Defender is fully removed as well. When i do an netstat -a i wont see any active session as well to the SDConnect. RE: Support thread for FullFixbySamik paid version - gcs190 - 12-03-2025 (12-02-2025, 06:27 PM)empetry Wrote: Hi, I installed version 04/25 of the truck but the Euro 6 vehicles aren't showing up. Where did I go wrong? A friend of mine said that only version 10/24 shows and connects. Is this information correct? Any available version works well, whether with VCI or SD Connect (in this case with the necessary modifications), however, if working on a bench with modules, my recommendation is not to use a version later than 04.2025 |
