RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - 1000mb - 05-27-2020
(05-13-2020, 07:03 PM)pesona Wrote: What's new:
May 13, 2020
  • DAS PKW/SMART/TRANSP Offline Programming & Online/Offline Entry of Retrofits & Modifications Ver 2.5 For XDOS/XPT 2019-09UP
    purpose:
    For XDOS/XPT 2019-09 UP
Realy big thanks to PESONA for this hard work, tried on 2019-09 and 2019-12 and all works without problem...
Just little question - did somebody figure out what about that VGSNAG2 module in 7.G transmission??? When you want to update it, DAS asks for pass and Control nr.2...
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - gjergji - 05-28-2020
Hello,
I am installing Xentry/DAS on XP, version 12.2014
Can I use Ver 2.5 For XDOS/XPT 2019-09UP,
Or do I have to use ver 1.01
Or should I use the one from Dietrich, DAS.Offline.Programming.2014.12.Patch?
What is the difference, I am confused?
Thanks in advance..
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - pesona - 05-28-2020
ver 2.5 for xdos/xpt 2019-09 onward. it is not for xp.
it is better you use DieTRih Offline.Programming.2014.12.Patch. it will be easier for you.
differences between versions?
History:
Rev 2.5:
- For XDOS/XPT 2019-09 UP (onward)
Rev 2.0
- Enable DAS Online/Offline Entry for Retrofits & Modifications (PKW)
- Covers ALL Transporter vehicles in DAS (from 4 transp type to 16 transp type) (Transp)
- Recognize sdflash in virtual drive (Transp)
Rev 1.01
- Add missing W204.041 (PKW)
- Full flashen folder. Make it easier to switch between Offline and Online Mode and to avoid unnecessary error(s) because of copy/replace. (ALL)
- Make example of menu file that you can use to choose Offline or Original. (ALL)
Rev 1.0
- Add 204 vehicles for Offline Programming (PKW)
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - bk-one - 07-02-2020
Please Help.
After Activate Offline In Xentry 12.2019
ONLINE scn not possible.
This Popup Message shows also after click offline programming in DAS but Offline Programming work.
Here is the message PIC.
https://ibb.co/HrvDRd0
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - OM617 - 07-03-2020
So if I get it right, with this addon I will be able to activate/personalize and learn ISM offline?
There would be no need for online account? Smile
I have 2020.03, and wonder for models like W211, W164,w203 and so on.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - emcho79 - 07-03-2020
(07-02-2020, 10:38 PM)BK-он Wrote: Моля, помагайте.
След Активиране на офлайн в Xentry 12.2019
ОНЛАЙН scn не е възможен.
Изпратете съобщение, което е публикувано и следва това, което се използва за програмиране в DAS, но не се използват програмни програми.
Това съобщение PIC.
решение на проблеми
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - ibockowsky - 07-04-2020
I have used ver2.5 on 2020.03 Xentry PassThru and it stoped working :/
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - fredkamau09 - 08-14-2020
I am looking for etn* files for w245, I appreciate the files attached by @emcho79, but do not contain series w245
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - texthamad - 08-22-2020
Hello guys
First of all thanks to all the great guys here specially pesona for their wonderful everlasting contribution to the community, now coming to the point I have fiddled around with some codings with a couple of modules just to get something new, everything else seem to work ok no fault codes but lost cruise control system, the car is not equipped with distronic, can anyone tell me which program module I have to offline program in DAS to get my cruise control working again. I am sure it has no hardware fault, its only a software problem. since we are talking about offline programming here, so thats why thought to share and request your help
