Permanent DTC P0562 - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: Permanent DTC P0562 (/Thread-Permanent-DTC-P0562) |
RE: Permanent DTC P0562 - Raints - 01-18-2017 K100 is feed side. Disconnect ac fan module and check again. RE: Permanent DTC P0562 - cartech - 01-18-2017 hello,i think could be inside ecu circuit cut,good luck. RE: Permanent DTC P0562 - kino0924 - 01-19-2017 (01-18-2017, 12:31 AM)Raints Wrote: K100 is feed side. Im confused about ac fan module. Are you telling me to disconnect blower motor and see how it goes? (01-18-2017, 01:38 AM)cartech Wrote: hello,i think could be inside ecu circuit cut,good luck. If ecu went bad, is it possible to swap to used ecu? I know some car can be swapped by replacing eeprom from original ecu to donor But Im not sure if its going to work on W245 ECU. Furthermore testing: Since I wasnt sure about ac fan module, I tested while ac is off (blower speed at 0) It turns out that if I put the car into ACC, the fuse 44 gets cut off rightaway I see yellow glowing from the fuse in short time, which tells me of excessive power going through the fuse. RE: Permanent DTC P0562 - Raints - 01-19-2017 Here you can see that M4/7 fan module gets feed from this fuse 44, thats why i suggest to disconnect it first. RE: Permanent DTC P0562 - kino0924 - 01-20-2017 (01-19-2017, 07:06 PM)Raints Wrote: Here you can see that M4/7 fan module gets feed from this fuse 44, thats why i suggest to disconnect it first. Still blowing!!!! what a magical mystic fuse 44!!! I am about to cry hahaha RE: Permanent DTC P0562 - Raints - 01-20-2017 Then check if your car have ac water valve y19/2 , if yes try to disconnect. And put simple 55w H7 bulb between fuse terminals, bulb should light up when there is short circuit , then you dont need but over again new fuse,and same time start check if wiring not damaged. RE: Permanent DTC P0562 - kino0924 - 01-22-2017 (01-20-2017, 12:05 PM)Raints Wrote: Then check if your car have ac water valve y19/2 , if yes try to disconnect. Hello Raints, I tried my ass off to figure out "AC Water Valve" but I failed to locate it. The closest thing that I found is "Heating water circulation pump" However, I cannot locate this part from my car (its not on there as the diagram shows as underneath of washer fluid reservoir). Also, when I see the brand new part, it only has 2 pins (not 3) which kinda tells me that I am looking into wrong part. I searched WIS/google crazy for two days but cannot locate Y19/2 Can you give me little more help to locate this? :'( Thank you so much RE: Permanent DTC P0562 - Raints - 01-22-2017 (01-22-2017, 12:39 PM)kino0924 Wrote:(01-20-2017, 12:05 PM)Raints Wrote: Then check if your car have ac water valve y19/2 , if yes try to disconnect. I checked in wis and there was mentioned that in 266960 engine which is yours dont have it. If it fitted then it should be between heat exchanger and engine hose. Looks like this: RE: Permanent DTC P0562 - kino0924 - 01-25-2017 Hello Raints, I couldnt locate AC Water Valve in my car. Its kinda obvious when WIS says its not available on my car anyway. So, based on your diagram that you posted few posts ago, I see that the wire after Fuse 44 branches to three different places. 1. Pin1 of N3/10 (ECU) 2. AC Water Valve(Y19/2) -> Pin33 of N3/10 (ECU) 3. X26/31 -> Z7/36z1 No .1 is not really matter since theres nothing between there... No .2 is not an option for me since I dont have AC water vavle Now, I m curious about No .3 It actually connected to Z7/36z1 and when I get info about Z7/36z1, I see lists of parts that is get feeded from there. Is that mean all those components that connected on Z7/36z1 is not working currently? Also, is that mean one of device from there can be a source of blowing fuse? Thanks. |
