SD Connect & 09.2016 Problem Firmware & DAS Error - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: SD Connect & 09.2016 Problem Firmware & DAS Error (/Thread-SD-Connect-09-2016-Problem-Firmware-DAS-Error) |
RE: SD Connect & 09.2016 Problem Firmware & DAS Error - crashndash - 11-09-2016 Going to reload the laptop today and start from the begining I'll post the result when I've reconnected the unit to the software RE: SD Connect & 09.2016 Problem Firmware & DAS Error - crashndash - 11-10-2016 Ok so I wiped the HDD and reloaded the image started again from scratch, connected the SD connect back up to the laptop and It appears to be working fine, I don't have a merc to test it on today so had to plug it into a transit for power but no firmware update messages or anything out of the ordinary all looks as it should i think? ![]() ![]() ![]() Redone the self test also RE: SD Connect & 09.2016 Problem Firmware & DAS Error - yriy - 11-10-2016 Now there is a test ram RE: SD Connect & 09.2016 Problem Firmware & DAS Error - Marcos - 11-10-2016 (11-10-2016, 02:22 PM)crashndash Wrote: Ok so I wiped the HDD and reloaded the image started again from scratch, connected the SD connect back up to the laptop and It appears to be working fine, I don't have a merc to test it on today so had to plug it into a transit for power but no firmware update messages or anything out of the ordinary all looks as it should i think? None of your pictures can be seen.Please use a different way to show them. RE: SD Connect & 09.2016 Problem Firmware & DAS Error - crashndash - 11-10-2016 (11-10-2016, 03:14 PM)Marcos Wrote:(11-10-2016, 02:22 PM)crashndash Wrote: Ok so I wiped the HDD and reloaded the image started again from scratch, connected the SD connect back up to the laptop and It appears to be working fine, I don't have a merc to test it on today so had to plug it into a transit for power but no firmware update messages or anything out of the ordinary all looks as it should i think? If you click on the picture you will see larger version RE: SD Connect & 09.2016 Problem Firmware & DAS Error - Marcos - 11-10-2016 (11-10-2016, 03:18 PM)crashndash Wrote: If you click on the picture you will see larger version Now it is fine. I can see the pictures. Also your mux is fine too based on your selftest. This makes me think that something is changed in your loaded image that is not good. Why you don't install sw. by yourself and use a fresh installation without using these crappy made virtual images. As you can see you can easily be tricked and think that the mux is dead. More than this, using such VM images will run your system slower and who knows what firmware will write into your mux that will kill it completely. RE: SD Connect & 09.2016 Problem Firmware & DAS Error - crashndash - 11-10-2016 It was purely for convenience I did not no how to set up myself and could not find all components separately although I think I probably could now if I had the files, image was from this forum and seemed to have good reviews. What ever the problem was it seems to be solved now! RE: SD Connect & 09.2016 Problem Firmware & DAS Error - Adolf Hitler - 11-24-2016 (11-08-2016, 02:12 AM)Marcos Wrote:(11-08-2016, 02:10 AM)crashndash Wrote: Do I need to update all the softwares shown in the picture? I clicked start on the top one clearceflashdisc.zip it said it had updated but still shows in the updates? can you help me with my xentry please RE: SD Connect & 09.2016 Problem Firmware & DAS Error - Mackhack - 01-03-2017 What is the problem AH? |
