RE: Support thread for FullFixbySamik paid version - jurpol - 12-18-2025
(12-18-2025, 05:51 PM)SQ5PGL Wrote: I had ODIS with Xentry XDOS, and it didn't work. After uninstalling ODIS and reinstalling Xentry, everything returned to normal.
Option 2: Download add-ons to Xentry
Thank you, I will try this in next days. May I know what did you mean with Download add-ons to Xentry? If is any other solution possible, it would be nice.
RE: Support thread for FullFixbySamik paid version - Wetwiki - 12-18-2025
(12-18-2025, 05:39 PM)jurpol Wrote: Hey,
I'm having weird issue in last months, I reinstalled xentry from 25.3 to 25.9 and I can't get Xentry to start. All other simulations and ACT (quick test) are working fine.. I have VCX SE and until now I didn't have any issues. Did someone got same issues and found any solution? I'm having ODIS on same system and worked without issues and is still working. Just Xentry causing me issues.. I reinstalled xentry 25.9 already three times, still same issue.. VCX was updated to latest version, but no change.. I used patch 8.3.9
Install a fresh Windows,
Then install ur xentry with no other brand programs on same windows
RE: Support thread for FullFixbySamik paid version - tafil - 12-22-2025
I just activated with the paid solution, the reason is i need the long key for Added "Actuation" tab for trucks, both in Xentry and Daimler Truck.
But after the activation I still see the old key is present, which is noticeable with the last part has 3 characters... I still have to test in truck, but i was hoping for a correct key and not some workaround.
RE: Support thread for FullFixbySamik paid version - avandgarde - 12-22-2025
(12-22-2025, 07:36 PM)tafil Wrote: But after the activation I still see the old key is present, which is noticeable with the last part has 3 characters... I still have to test in truck, but i was hoping for a correct key and not some workaround.
If you don't know what you're talking about or you don't know what you're talking about, don't write nonsense. Fing20
RE: Support thread for FullFixbySamik paid version - Sam!k - 12-23-2025
(12-22-2025, 07:36 PM)tafil Wrote: I just activated with the paid solution, the reason is i need the long key for Added "Actuation" tab for trucks, both in Xentry and Daimler Truck.
You need key with some characters or need working key?))
RE: Support thread for FullFixbySamik paid version - ChengLynn - 12-23-2025
Hi, i have installed xdos 12.2025 and have used FullFix Version v8.4.0
I want to use my SDconnect C4.
IP for LAN is set to 172.29.127.128
I have use SDC4-VCI Switcher to set it for SDC4.
The Mux is Connect with LAN to Pc, but
the Mux is not showing in SDconnect Toolkit.
Did someone install new Xdos 12.2025 with SDconnect C4?
On my System don‘t work.
RE: Support thread for FullFixbySamik paid version - Sam!k - 12-24-2025
(12-23-2025, 11:18 PM)ChengLynn Wrote: Hi, i have installed xdos 12.2025 and have used FullFix Version v8.4.0
Check firewall
RE: Support thread for FullFixbySamik paid version - ChengLynn - 12-24-2025
Many thanks, you are Right, the Firewall have blocked SDconnect Tool.
RE: Support thread for FullFixbySamik paid version - walzit69 - 01-04-2026
Good  afternoon,
I need help from anyone who has encountered this problem. I installed XDOS version 04.2025 Dailmer Truck. VCI6 does net want to connect to XentryTruck. I disabled and enabled the firewall, but there were no changes. i confirm that the search with GSR does not want to connect. When I select without GSR, the connection is established, the battery charge is displayed, but then it says that the charger is not from the car and disconncts.
