RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - pesona - 11-17-2020
(11-16-2020, 10:31 PM)bumer_m3 Wrote: hi, i downoloadet "Smart offline programming" Package from post 1.
PKW offline is installed and works. But for Smart i get no menü with possibility to programm offline. Folders are copied like they have to be. What im doing wrong? Xentry 12/2018
hi mate,
have you use the sample menu to switch to smart offline?
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - BigGuy - 11-17-2020
Will it work with 2020/09 version ?
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - thanh1974 - 11-17-2020
(11-17-2020, 10:08 PM)BigGuy Wrote: Will it work with 2020/09 version ? please do me favor mate ......open your eyes and read the post & research.....up 2018 is the most what u thinking 09-2020 ?? don't flooded the post if i was u.. spend times and research before throw out question will not make any scenes for u with new latest version co do OFFLINE mode, if it's does u a last person know about it
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - bumer_m3 - 11-18-2020
(11-17-2020, 05:22 AM)pesona Wrote: (11-16-2020, 10:31 PM)bumer_m3 Wrote: hi, i downoloadet "Smart offline programming" Package from post 1.
hi mate,
what is sample menu? I connected automaticly to the car, and after this, enter gearbox unit, functions, software update. But get only online xentry menu
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - Fenix5 - 11-19-2020
Hello, install everything as it says in the first post, mount the disk in the virtual drive and when I go to Flash it tells me this and I don't know what else to do
The car is a blue class A 169 efficient sim2066
[img=1080x1730]file:///C:/Users/fran/Downloads/WhatsApp%20Image%202020-11-18%20at%203.43.41%20PM.jpeg[/img]
VeDoc data for the 169 series is not available in the diagnostic device.
Possible cause: The series selected in the DAS does not match the vehicle
-> Series: 169
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - pesona - 11-19-2020
(11-18-2020, 10:02 PM)bumer_m3 Wrote: what is sample menu? I connected automaticly to the car, and after this, enter gearbox unit, functions, software update. But get only online xentry menu
hi,
look at point no 4. download the batch file, copy to your desktop and run it.
default is the original mode, to use for scn/programming online or for updating addons.
choose 'offline' mode.
after the offline job is done, don't forget to set it back to the original mode.
(11-19-2020, 02:48 AM)Fenix5 Wrote: Hello, install everything as it says in the first post, mount the disk in the virtual drive and when I go to Flash it tells me this and I don't know what else to do
-> Series: 169
hi,
use necraxx utility to search for the vedoc and flash data for 169 series
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - thanh1974 - 11-21-2020
(09-20-2020, 10:56 PM)oleg71175 Wrote: (07-26-2016, 05:10 PM)pesona Wrote: What's new:
May 13, 2020- DAS PKW/SMART/TRANSP Offline Programming & Online/Offline Entry of Retrofits & Modifications Ver 2.5 For XDOS/XPT 2019-09UP
purpose: For XDOS/XPT 2019-09 UP
purpose:to update ecu firmware & Offline/Online Entry of Retrofist & Modifications
Note:
Change to original mode when update addons. Daimler always update to increase security in Online Programming!!!
If not, the offline patch will get error when using.
History:
Rev 2.5:
- For XDOS/XPT 2019-09 UP
Rev 2.0
- Enable DAS Online/Offline Entry for Retrofits & Modifications (PKW)
- Covers ALL Transporter vehicles in DAS (from 4 transp type to 16 transp type) (Transp)
- Recognize sdflash in virtual drive (Transp)
Rev 1.01
- Add missing W204.041 (PKW)
- Full flashen folder. Make it easier to switch between Offline and Online Mode and to avoid unnecessary error(s) because of copy/replace. (ALL)
- Make example of menu file that you can use to choose Offline or Original. (ALL)
Rev 1.0
- Add 204 vehicles for Offline Programming (PKW)
PKW/SMART/TRANSPORTER
Ver 2.5:
1.PKW Offline Programming, SCN Offline Coding & Offline Entry for Retrofits & Modifications
Software: Xentry XP, XDOS(32/64)
Release: 2015 - 07/2019.
How to:
1. Rename original "Flashen" folder in: das\trees\pkw to "FlashenORI"
2. Extract and copy the offline flashen
So in the das\trees\pkw you have two folders:
Flashen : for offline programming
FlashenORI : original folder. in case you need to use for online programming
Make a simple batch file to have a menu to choose “OFFLINE” AND “ORIGINAL” to switch between these folders.
It is better including changing the name of Flashen folders in SMART & Transporter too.
ver 2.0:
What's new in ver 2.0:
- Enable DAS online/offline Entry for Retrofits & Modifications
ver 1.01
What's new in ver 1.01
- add 204.041
notes:
- for some xdos release, there is no akttab.csv in the PKW sdflash folder
here it is:
2. SMART Offline Programming
Requirement: Need Offline Programming PKW installed
how to:
1. Rename SMART Flashen folder in:
DAS\Trees\Smart\Flashen to FlashenORI
2. Extract and copy the offline flashen DAS\Trees\Smart
So in the das\trees\Smart you have two folders:
here it is version 1.0:
3. TRANSPORTER/VAN Offline Programming
how to:
1. Rename TRANSP Flashen folder in:
DAS\Trees\Transp\Flashen to FlashenORI
2. Extract and copy the offline flashen to DAS\Trees\Transp
so you have 2 folders.
It is better including changing the name of Flashen folders in ALL (PKW, SMART, TRANSP).
here it is version 1.0: (q.e.d. proven here)
4. MENU
This is example of menu file that you can use to choose Offline or Original.
Compatible with: WINXP and latest OS
For: Xentry XP, XDOS 32bit, XDOS 64bit
Version: 1.1 (Include PKW, SMART, TRANSPORTER/VAN)
What's new in ver 1.1:
- copy to desktop. it will know what OS, and 32/64 bit automatically
if the menu above is failed on your OS, here is the source file that you can adjust or delete the determination of OS.
5. PKW & SMART Offline programming for XENTRY XP
Software: Xentry XP
Release: 2014
Feature: Full Flashen folder + how to
How to: (1.01)
1. Rename original flashen folder in: das\trees\pkw to e.g: flashenORI
6. Transporter Offline programming for XENTRY XP
Software: Xentry XP
Release: 2014
How to: (1.0)
1. Rename original flashen folder in: das\trees\transp to e.g: flashenORI
TRANSPORTER/VAN AKTTAB.CSV
here is replacement for missing "akttab.csv" in Transporter e.g 12-2015, 09-2016 version etc
7. Transporter INBETRIEB.INI V2 Released in 03-2017 for All DAS Version :
what's new:
1. it covers ALL Transporter vehicles in DAS (from 4 transp type to 16 transp type)
2. it will recognize sdflash in virtual drive
how-to:
- extract & replace the inbetrieb.ini of the "offline Flashen" in:
DAS\trees\Transp\Flashen\ini\
here it is:
8. CD SDFlash Mini 2.0
If your sdflash in harddrive is not good/complete/missing a file(s), DAS will try to look for SDFlash CD. Fix that sdflash or Mount this sample CD SDFlash Mini in virtual drive when doing offline programming.
what's new ver 2.0:
- add FDOK folder from SDFLASH 10-2008 up to 03-2018 (PKW, SMART,TRANSP)
Disclaimer:
for official and educational use only. If you use them for any illegal purposes (such as programming stolen car/smart/van), this is your own responsibility. i'm definitely against it.
EDIT:
Tips & Tricks
Quote:I have tested Offline Programming with xdos 03-2018 myself in real diagnostic. I use self-made sdflash (combine 10-2008 up to 03-2018 sdflash) and standard sdflash 07-2014 (i choose because it still has many etn* inside)
here are some pictures:
PKW:
ETC update with self-made sdflash up to 03-2018. Sdflash is copy to harddrive:
ETC
ME update with SDFLASH iso 07-2014:
ME
SMART:
Simulation with real vin
Transporter:
CDID2 (offers 3 software update from self-made sdflash)
Quote:DAS only allows max 3 new firmware in one sdflash.
if your self-made sdflash has more than 3 new software, DAS will warn: "sdflash contents has xxx new updates. Contact help desk. Click ok or cancel".
if you click ok, DAS will not update and inform you that there is no newer software update.
for xentry version 2017-12, here is good information from xzt in post 188:.
(12-02-2017, 08:46 PM)xzt Wrote: Hi, I was tested your file pesona on version 12.2017, and after few test not work , but I was find that are missing some file, I was search old dvd flash data,to work normaly you need folder FDOK,file etns,etnh,etnt,etc from version old 2012,2011,2010,2009,for pkw,transp,smart tested and work fine in simulation with real vin car !
keep good work,regards!
Q:
(02-09-2018, 08:04 PM)megacrazy Wrote: Thanks for putting work into this pesona.
Unfortunately I am having issues with programming Comand. I'm running into the same issue other people had, namely "Insert DVD Labeled Star Diagnostic" after going to "Offline Programming" and advancing through the first prompt.
Here's some info:
- I'm running 2016.5 off a Dell laptop, Windows 7
- "Offline" programming shows up after replacing the "Flashen" folder
- SDFlash.ini has correct links to the appropriate folders
- I have downloaded various ISOs from the SDFlash collection and mounted them, no change
- The Inbetrieb.ini file seems to have the correct paths, I've even added new ones after mounting the ISOs under different drive letters, no change
- Replaced the entire "Release" folder with one from the correct ISO. The one I had was slightly less files...still no change.
- The system doesn't seem to check the CD drive at all. I have a firmware cd in there and it doesn't even start spinning.
Any ideas on what to try next? Thanks!
A:
(02-10-2018, 09:10 PM)megacrazy Wrote: So i figured this out. For some reason as soon as I changed my DAS.inf version/date to match the flash data date it started working. The next issue was missing #FDOK folder which I copy/pasted. Everything worked after that.
(02-11-2018, 12:22 AM)megacrazy Wrote: I copied the entire 2016.5 release folder to SDFlash\Release. The "profi_cd.ini" file in that folder had "DAS-CD-NR=05/2016"
[DasDataVersion] in Das.inf was set to 2014 even though the "official" version I have is 05/2016. I changed that date to 05/2016
Basically as long as those 2 dates matched (in das.inf and profi_cd.ini) it wouldn't ask for the Star CD anymore and it would go to the next step of the flashing process, displaying flash data that was available. It also detected any ISOs I mounted, regardless where they were mounted from (same drive/usb etc.)
Another links:
SDFLASH-Collections
SDFlash Collection 2008-2017 (torrent)
Thank you very much for your input. offline programming went off with a bang. still run scn coding. but you're done. [font="MHH Font", Calibri, sans-serif]What's new:[/font]
[font="MHH Font", Calibri, sans-serif]May 13, 2020[/font]- DAS PKW/SMART/TRANSP Offline Programming & Online/Offline Entry of Retrofits & Modifications Ver 2.5 For XDOS/XPT 2019-09UP
SO OFFLINE Version can able still using 09-2019 NOT 03/2019 ??? can u or some one confirm ?? i about down load install 3/2019 .. i have successfully install OFFLINE programing 12/2018 work ok no sure it's will work as u said 09/2019 .......let me know please thanks u sir
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - wosanyn31 - 11-21-2020
It work ok on 12.2019
I want to reinstall in 32bits but without add-ons support there are some faults
(11-21-2020, 03:56 AM)wosanyn31 Wrote: It work ok on 12.2019
32 bit is only HHT but so x64 will able add on..?? cool thanks mate i am down load version 12.2019
