RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - igorukr - 11-22-2020
Sorry for asking again, I am confused here.
Will it work on XENTRY 3/2020 and 9/2020?
Or latest off line version is 12/2019?
Offline doesn't work on my 9/2020, so I am not sure, is it me doing something wrong, or first I should downgrade to 12/2019.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - tripix - 11-23-2020
Hi guys,
I confirm that the offline programming does not work on 12 2019 I have made all the patches of sig pesona.
the problem for me is the akttab file.
we are waiting for Mr. Pesona
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - igorukr - 11-23-2020
(11-22-2020, 07:50 PM)igorukr Wrote: Sorry for asking again, I am confused here.
Looks like it works now.
I have not programmed yet, but I got to the point it tells me that new software is available, or unit is already programmed with latest version , depending on unit I working with.
The trick is proper Flash CD.
Should  have Fdoc folder and et* files.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - saimon - 11-25-2020
Hi friends, it's possible to do all this on 2018-5 release | 2019-12?
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - pesona - 11-25-2020
hi,
i have tested das offline programming in xdos 2020-12 and it works (there is a das menu to choose online or offline mode).
use the sample menu and run as an administrator and switch das mode from original/online to offline mode.
default is original/online mode for updating addons or doing scn online.
use sdflash from das below 2014 but if you can't find the flash file or vedoc, use @necraxx app sw_finder to get it online.
hope this help
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - BiGGZ31 - 12-02-2020
Hi Pesona,
to activate offline transporter/van programming is it enough to copy files only from latest 2.5 package to PKW and Transp folders or previous steps are required to.
Im trying to program ESP8 639 but virtual drive and USB are not recognized by offline menu on 06.2020 Xentry.
[img][Image: Y4AFIBG.png][/img]
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - mbparts - 12-19-2020
Today we use offline to flash w221. we get error i have seen here that sdflash version older than das version, we using 07/19 and my collection was earlier version--05/19.
I try to change, but still asks for cd... Can i change version 07/19 to match 05/19 or rename flash collection to 07/19 ??
Just checking which route is correct as we can not seem to make right.
Thank you Pesona for the collection some time back and the quick batch file offline works very good.
Just a little direction on which changes to make please...
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - pesona - 12-19-2020
(12-19-2020, 05:52 AM)mbparts Wrote: Today we use offline to flash w221. we get error i have seen here that sdflash version older than das version, we using 07/19 and my collection was earlier version--05/19.
hi,
afaik,
- just click 'no' to change the cd and click 'yes' to continue.
- the favorite sdflash are collections before 2015
- don't forget to check akttab.csv in the pkw folder
- of course you can edit the profi_cd.ini the same as your das release but, imo, it is easier to click no and yes.
if you can't find the flash file, you can use necraxx utility
hope this help
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - plopek - 12-31-2020
Hi guys
1.I've been trying to digest all in that tread but  still cant find password for SD39.800 archive.
Can someone help me find it?
2. Is it possible to change injectors in W447 Vito 2017 offline ?
Thanks in advance .
I wish you all Happy New Year !!!
