RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - wgwgwg - 01-01-2021 Hello guys, I have installed Xentry OpenShell 09.2020 Acronis image. Very nice job. Thousand thanks for this. Now I have the following problem: My car is W216 CL600 from 2011. I have problems with the Motor-CAN. My transmission control suddenly changed to the status "not coded". And my engine does not even start. So I try to make DAS offline-coding. Starting the process in DAS-programming it tells me "Return:1:Consumer not found" and "cant connect the socket to listener". I press "ok". I have mounted several CDs from downloaded SDflash-collections 2017-18 and 2008-2017. "The Control-unit-Software is not awailable" + "ETN for model 216 could not be found" By manually search I cannot find any file in the complete collection with an according number 216. Only 221 or 217, etc. And no file with ETC. Am I basically not able to offline-flash my transmission controlbox ETC with this collections? Thanks for help Wolfgang RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - Pajinuk - 01-18-2021 5. PKW & SMART Offline programming for XENTRY XP Hello, please I copy your files and when start DAS work standalone but still cant see C class model type 204 can you help me, PLease?
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - Rocinante - 01-18-2021 You need the DAS 204 fix, this is not it.. RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - pesona - 01-18-2021 @Pajinuk download it here: https://mhhauto.com/Thread-SPECIAL-FUNCTIONS-for-DAS-Vehicles-PKW-SMART-VAN-IMO-BUS-LKW?pid=1430713#pid1430713 DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - Ptah-fr - 01-31-2021 Hi everybody I would like to update my control unit of my G class 2013. I have xentry passthru 2020.12 with tactrix openport 2.0 Could you say me if this solution allow me to program offline my control units with my equipment ? DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - Ptah-fr - 02-02-2021 (01-31-2021, 02:28 AM)Ptah-fr Wrote: Hi everybody Any help would be appreciated [emoji2] RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - dmajooo - 02-03-2021 Hi guys, I need offline flash for my W221 DTR modul (distronic) everything go without problems and at the end it will show as follow..... any solution ?? thaaanks DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - Ptah-fr - 02-04-2021 I have copied all files in my xentry directory. Sadly when I launch update software in xentry, xentry ask me to connect me online. Do you have a tuto to install properly DAS offline ? RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - pesona - 02-04-2021 @Ptah-fr hi mate, I. look at point no 4 the simple menu. extract to your desktop, and you will get a file with 'bat' extension. run as administrator, then there are 3 choices. 1. original/online mode (default) 2. offline mode 3. exit choose no 2. II. mount sdflash from 02.2011 or 07.2014. download them from sdflash collections in this forum or use necraxx utility to find the needed file and copy to your local sdflash or kind of. III. after using it, run the menu again and choose no 1 original/online mode for update addons etc btw, there is no one who gives feedback for the 2.5version (xentry 09.2019up). probably they move to use vediamo instead or simply not work. disclaimer: i don't support it. it is for education only and i hope it will bring a benefit for the mb community to learn about it. |
