DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - Ptah-fr - 02-04-2021 @persona A great thank for your howto for newbies [emoji2] I will try for education But I understand now the best way to update Calculator is vediamio ? Right? RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - japan_mpl - 02-04-2021 hello help me I have installed Xentry OpenShell 12.2020 Acronis image. I wanted to program offline and did the following The model is smart 451 mhd 1. Rename original "Flashen" folder in: C:\ProgramFile(x86)\Mercedes-Benz\DAS\trees\pkw\Flashen to "FlashenORI" C:\ProgramFile(x86)\Mercedes-Benz\DAS\trees\Smart\Flashen to "FlashenORI" C:\ProgramFile(x86)\Mercedes-Benz\DAS\trees\Transp\Flashen to "FlashenORI" 2.Extract and copy the offline flashen PKW/SMART/TRANSPORTERVer 2.5 C:\ProgramFile(x86)\Mercedes-Benz\DAS\trees\pkw\ C:\ProgramFile(x86)\Mercedes-Benz\DAS\trees\Smart\ C:\ProgramFile(x86)\Mercedes-Benz\DAS\trees\Transp\ 3.Extract and copy the akttab.csv C:\ProgramFile(x86)\Mercedes-Benz\Sdflash\Release\PKW 4. Copy to desktop. MENU OFFLINE ORIGINAL MODE PKW_SMART_TRANSP 1.1.BAT 5.Start MENU OFFLINE ORIGINAL MODE 1)OFFLIN MODE 6.Extract and copy INBETRIEB.INI DAS\trees\Transp\Flashen\ini\ 7.Launch xentry 8.Launch DAS 9.Select N15/6 (Sprintshift control module) 10.Program control unit 11.Select offline (diagnostic unit not networked) I get an error message <getCacheNrc>:CSD_8(Routing error,may be wrong memo code) Response of XENTRY Framework:RETURN:1:Consumer not found! Select NO akktad.csv missing Virtual mount SDFLASH MINI <getCacheNrc>:CSD_8(Routing error,may be wrong memo code) Response of XENTRY Framework:RETURN:1:Consumer not found! Am I doing something wrong somewhere? RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - pesona - 02-04-2021 @japan_mpl hi mate, you do it correctly. ![]() i don't dig it again after i got that information some time ago. i think it is time to move to vediamo and i will delete the ver 2.5 this weekend ![]() so the offline programming is worked for xdos up to 2019-07 i apologize for any inconvenience this may cause best regards btw, i have to admit that i should update and write the complete "how-to install and do offline programming" like you did. probably, because of boring since it is already 6-7years in a row. EDIT: @webmaster i can not delete the 2.5 release nor edit the subject. DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - Ptah-fr - 02-05-2021 (02-04-2021, 05:19 PM)pesona Wrote: i think it is time to move to vediamoOk so I give up this tool to switch to vediamo. Thanks for your help [emoji106] RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - avandgarde - 02-06-2021 (02-04-2021, 05:19 PM)pesona Wrote: @japan_mpl I think 9/2019 also works well as Off. There were some problems in version 12/2019, I didn't try the newer ones as off. RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - BigGuy - 02-17-2021 is there a way to enable 2020/09 offline programming ? by the way I made it work on 2019/09 RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - pesona - 02-18-2021 thanks, guys @avandgarde & @BigGuy. at last, i get the feedbacks that release 2.5 works. (02-06-2021, 12:46 AM)avandgarde Wrote: I think 9/2019 also works well as Off. There were some problems in version 12/2019, I didn't try the newer ones as off. i don't get information from the forum about your post. so the problem with release 2.5 starts on 12/2019. noted mate. @BigGuy basically, for 2020/09, it is the same patch as 2019/09. it would be great if you can try and give feedback with 2020/09 RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - Diaguna - 02-18-2021 (02-18-2021, 05:18 AM)pesona Wrote: thanks, guys @avandgarde & @BigGuy. at last, i get the feedbacks that release 2.5 works.Work on 2020/09 and 12/2020 RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - pesona - 02-18-2021 (02-18-2021, 12:45 PM)Diaguna Wrote: Work on 2020/09 and 12/2020 hi mate, it is in a real car does offline programming or just the offer for offline programming in das menu? please clarify it. thanks |
