RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - robertpenz - 04-09-2021
I wantz to programm OFFLINE some things for a Smart 451
but I still onloy have online coding.
How can I get offline?
Xentry version 12.2020
I already added the FLASH Folder (2.5 version)
Still same picture
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - MecK4x4 - 04-10-2021
HI,
I'm using Xentry 12.2020, i've followed the insstructions but than offline coding isnt working.
it give me this error:
File: "akttab.cvs" missing.
(C:\Program Files (x86)\Mercedes-Benz\Sdfash\Release\smart)
possibly missing an akttab.cvs file also in Smart folder? would be the same one for PKW or i need a different one?
alternatively do you know where can i find a version of das for offline coding? thx
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - pesona - 04-11-2021
hi,
for offline programming smart, you have to install the offline programming for pkw too in order to get the offline programming option.
for missing "akttab.cvs", you need to get akttab.cvs for smart from the previous xdos that have it.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - MecK4x4 - 04-11-2021
hi persona thankyou for the quick reply,
yes I did install eveything like you explained in post n1.
I'm using a Passthru vesion, would a akttab file from a xdos work?
I've tryed mounting a sdflash disk 2017 (that contains an akttab file for smart ) this time it worked but the program failed to identify a match for my car. should i try with an older Sdflash ?
this is tha current unit:
Control unit: TCU_451
Control unit SEQ
MB object number for hardware 451 545 40 32
MB object number for software 0014463395
Supplier Mitsubishi Electric
Hardware status 08/04
Software status 00/50
Diagnosis identifier 4
Version (internal) DK0004
Coding F100000000000000
thankyou very much guys
you are welcome mate.
my reply was also for @robertpenz too.
akttab file from a xdos is no problem.
you can try with older sdflash 2012.11 or use necraxx app to search for your correct current cff
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - blueabyss - 04-11-2021
Thank you Peson great job.
In version 03/21, I inserted the missing actab in PKW (I took 7/2014 here) and then the message appears, see the picture.
I confirm no - not to implement - and everything continues - without defects.
The error is when entering through Xentry.
When entering via DAS - the error is the same - the fix is to run Xentry
How to remove this message - is it a solution?
imo, for latest xdos, it is time to use vediamo or dts monaco for offline programming.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - bbli2000 - 04-12-2021
(03-09-2021, 07:47 PM)pesona Wrote: i am blocked by the system to edit the first post and i have not pm webmaster about it yet
btw, maybe someone needs version 2.5, here it is
In this package, the offline FLashen folders are names as FlashenOff. When copying them to the target locations, should they be renamed as flashen, i.e., without "off"?
Thanks.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - MecK4x4 - 04-12-2021
Control unit SEQ
ok I’m trying the swfinder app , what value should I put in the search box to get te lates sw available? I’ve tried some but could find any match
thankyou very much guys for your patient.
