RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - shewush - 04-21-2021
Sorry, where can i find Rev 2.5 of a offline prog patch to xdos?
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - pesona - 04-21-2021
(04-21-2021, 01:23 PM)shewush Wrote: Sorry, where can i find Rev 2.5 of a offline prog patch to xdos?
temporary it is in here:
https://mhhauto.com/Thread-DAS-PKW-SMART-Transporter-Offline-Programming-2014-2015-2020?pid=1973030#pid1973030
someday i hope i can update the first post of this thread again.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - Benz71 - 05-03-2021
Any fix for opening W207 in DAS? It`says Prototype and I don`t have access. I can choose engine etc. but then it stops. I`ve tried both manual and with VIN. See pics.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - Benz71 - 05-04-2021
Anyone? See above. Not sure if I have posted in the right place.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - fachmi - 05-11-2021
Hi @pesona
I successfully update 0014488810 to 0084488010 with DAS 03/2020 and 2014-12 sdflash. Unfortunately, It ask for me SCN coding after it finished the update which I dont have it. Now the car can start but transmission does not work. Coding status is Unknown Data.
I tried to code using Vediamo with various vgsnag2.cbf but always get message negative response from ECU.
Is there any way to downgrade again to original flash or to make solve the problem?
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - teris - 05-11-2021
hello
Mr @Pesona
where we must put the FDOK folder from SDFLASH 10-2008 up to 03-2018 (PKW, SMART,TRANSP) ??
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - pesona - 05-11-2021
@fachmi
probably doing scn online will solve your problem
@teris
you have to see the example from a sdflash folder with a fdok file to know the logic where to put it
Is it supposed to behave like that or I made a mistake during the update?
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - zcc - 06-10-2021
(04-14-2021, 09:17 PM)MecK4x4 Wrote:
(04-11-2021, 04:19 PM)pesona Wrote: you are welcome mate.
my reply was also for @robertpenz too.
akttab file from a xdos is no problem.
you can try with older sdflash 2012.11 or use necraxx app to search for your correct current cff
Thx persona, I used an older sdflash CD
just as a feedback your fix is Working on 03.2021 aswell ! with an Openport 2.0
Can you please explain to us how that can work? I am so interested in making DAS 03/2021 do the offline programming. Thank you in advance.
