RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - pesona - 10-24-2016
hi too,
noted mate. make sure your hardware are health using self diagnosis in star utilities.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - anttist - 10-25-2016
Here's my self diagnostics log. Does it look allright? I have tried with USB<->RS232 adapter and Expresscard RS232 port. They both seem to work the same, but in fact they both use Prolific USB<->RS232 chipset so although the form factor is different they work the same.
If this is likely to be a communications issue I could try to loan a docking station with serial port.
Thank's for your great work!
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - anttist - 10-27-2016
I tried FTDI USB-RS232 adapter and re-installed everything. No difference. Has anybody got the smart offline programming working with this solution?
I noticed that even when trying to program MEG Control Unit on upper right corner always says SAM_450. Maybe this is normal, I don't know.
EDIT: I tried programming the SAM which also had new version available and that was successful! So it seems to be related to the MEG somehow.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - pesona - 10-28-2016
hi mate, thanks for the feedback.
it would be perfect if you kindly make the screenshots of your smart programming and upload it here.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - pacman34 - 11-02-2016
I have version 9/15 and installed the transporter/van patch. I am unable to do offline programming because it requires a password. Did I do something wrong or does this patch have a password. Thanks
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - pesona - 11-02-2016
you can add transporter password free here:
http://mhhauto.com/Thread-No-Password-in-Special-Function-FIX-DAS-XENTRY-2011-UPDATE?pid=30861#pid30861
regards
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - Quark - 11-03-2016
Great job, thank you so much.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - odessit s pentagona - 11-04-2016
Great job, thank you so much. TupTupFing32
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - Mackhack - 11-07-2016
This is what I get when I try your menu program on Win XP with Xentry 12/2015.
Any idea what's wrong?
