SDconnect Toolkit INTEGRATION TO NEW XDOS VERSIONS 03/2024 & UP - Printable Version
+---- Thread: SDconnect Toolkit INTEGRATION TO NEW XDOS VERSIONS 03/2024 & UP (/Thread-SDconnect-Toolkit-INTEGRATION-TO-NEW-XDOS-VERSIONS-03-2024-UP)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
RE: SDconnect Toolkit INTEGRATION TO NEW XDOS VERSIONS 03/2024 & UP - vwpassat14 - 10-16-2024
(10-16-2024, 07:45 PM)imran Wrote: Chak The line cable
Sent from my CPH1969 using Tapatalk
Is not there the proplem
RE: SDconnect Toolkit INTEGRATION TO NEW XDOS VERSIONS 03/2024 & UP - weryo - 10-16-2024
why you apply this fix on Xentry 12/2020.....it not need,..on this old versions all works normall without any fixes.
as seen your multiplexer is not visible at all,..insteda all settings you show are correct.
probably your multiplexer or cables are bad,...please check on different xentry system computer to see if your sd connect is visible there.
good luck mr.passat
(10-16-2024, 08:57 PM)weryo Wrote: why you apply this fix onĀ  Xentry 12/2020.....it not need,..on this old versions all works normall without any fixes.
good luck mr.passat
Multiplexer works on another laptop dell 630 very well with xentry 7/2017. Problem is not there I checked already.
ok,..check your lan port ,..just check with internet,...and once again i ask you,..why you apply this fix,...its for versions from 2023 and further,..your 2020 version use an old sd connect server,..2.14,...and old sd connect firmware 2.11.
probably its full mess at your side,..i could reinstall all from begining and never buy ready to go xentry systems from internet.
good luck Sir
(10-16-2024, 09:12 PM)weryo Wrote: ok,..check your lan port ,..just check with internet,...and once again i ask you,..why you apply this fix,...its for versions from 2023 and further,..your 2020 version use an old sd connect server,..2.14,...and old sd connect firmware 2.11.
good luck Sir
Could you do install xentry2023/2024 on windows7 running on Dell630?
no,..xentry 2023 or xentry 2024 work only on win10x64,..and dell 630 is very old and week laptop for xentry 2023,2024,..you need laptop with i5,ram at least 8gb and ssd 500
(10-16-2024, 10:33 PM)weryo Wrote: no,..xentry 2023 or xentry 2024 work only on win10x64,..and dell 630 is very old and week laptop for xentry 2023,2024,..you need laptop with i5,ram at least 8gb and ssd 500
I have 3 Dell630 and works very well. Please tell me what is the maximum for Dell 630 to install xentry?
12.2022 is the latest,..but in win 10x64,..or 0321 on win 7x64
RE: SDconnect Toolkit INTEGRATION TO NEW XDOS VERSIONS 03/2024 & UP - vwpassat14 - 10-17-2024
(10-16-2024, 11:58 PM)weryo Wrote: 12.2022 is the latest,..but in win 10x64,..or 0321 on win 7x64
I saw win7/32bits run very well in comparison Win7/64 where I had several problems. Do I try in the futureĀ  xentry2021 as win7/32?
On the other hand, you or someone else could send me ConfigAssist folder, please. I think there is the problem now.
Thank you.
