RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - amxcs - 07-06-2021
Can I update modeles with Xentry Pass-thru version 12.2020 + openport 2.0?
W211 e220cdi 150hp
RE: PKW/SMART Programming Offline 12/2015 & 2016. Tested work. - CARAGE - 08-14-2021
(07-27-2016, 04:16 PM)pesona Wrote: Today i go to my friend to test this offline programming myself.
W204 and W211. Tested and it works.
Now, i need your help mates.
1. I was ask by a member here that he stumbled with release code and test digit 2, like this:
where do you get this numbers?
i think i know how to bypass it if i connect with the car and stumble with that.
but i need to know, if you don't bypass these numbers, where and how do you get this number from?
2. am i safe if don't connect battery charger?
offline programming commercial vehicles, wil begin after switch engine and start OFF. That's why i have peace in mind and don't need battery charger. for pkw, i read that the fan will on hardly etc etc..
i will continue with F3. but before that i need the information please.
Can anybody do CGW Coding through TeamViewer?
If anyone  then please know me...
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - art_arev - 08-20-2021
Is there a link for version 2.5 XDOS 2019 UP?
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - pesona - 08-20-2021
(08-20-2021, 03:00 AM)art_arev Wrote: Is there a link for version 2.5 XDOS 2019 UP?
hi,
look at this post:
https://mhhauto.com/Thread-DAS-PKW-SMART-Transporter-Offline-Programming-2014-2015-2020?pid=1973030#pid1973030
hi,
look at this post:
Thank you so much my friend
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - art_arev - 08-29-2021
Version is 06.2021. Offline flashen inserted. Offline /online screen comes up fine. After selecting offline I get this error. Any idea?
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - pesona - 08-29-2021
(08-29-2021, 06:02 PM)art_arev Wrote: Version is 06.2021. Offline flashen inserted. Offline /online screen comes up fine. After selecting offline I get this error. Any idea?
i have not tried it but if you use das standalone, try to run xentry after running das standalone.
I don't have DAS standalone installed.
Also 06.2021 didnt have aktab.csv. so I got it from a 2016 version(just giving some info)
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - art_arev - 08-30-2021
Ok, so I tried again. When the error popped up asking to reload or not, I pressed no. It found a new software & I updated my Instrument Cluster. So offline still works with 06.2021 as long as you press No in the error box.
But it will be nice to have a solution so the consumer not found error doesn't pop up
