RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - art_arev - 09-02-2021
Guys has anyone tried to do offline with new SDFlash and a older Xentry? Lets say XDOS 2016 version with SDFlash 06.2021 version. Will that work?
(09-02-2021, 03:59 AM)art_arev Wrote: Guys has anyone tried to do offline with new SDFlash and a older Xentry? Lets say XDOS 2016 version with SDFlash 06.2021 version. Will that work?
I just tried. The older Xentry doesn't see the newer SDFLASH.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - bnunes39 - 09-04-2021
Hi, i have star diagnostic DATA VERSION  09/2019, the offline files for PKW are they applicable to my star diagnostic.
thanks
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - gcs190 - 09-04-2021
(09-04-2021, 03:24 PM)bnunes39 Wrote: Hi, i have star diagnostic DATA VERSION  09/2019, the offline files for PKW are they applicable to my star diagnostic.
thanks
Yes
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - rengti16 - 09-08-2021
Bonjour et merci pour tout le travail et le temps que vous nous accordez j'ai réussi a pouvoir passer en mode hors ligne avec mon xentry 06/2021 ver 29.8.2.0
Je dois codé mon EGS3 suite au remplacement de ma boîte automatique/722.640--->722.699
Pourriez vous me le soft que je dois prendre merci
Calculateur EGS3
Numéro MB. 003.446.41.10
Fournisseur. Siemens
Version matériel. 48/06
Version logicielle. 50/06
Code diagnostic. 3/83
Date fabrication. 15.12.07
Variante Diagversion 53_EGS53
Version donnée diagnostic. 02.01.83
Merci pour votre aide 👍😉👍
RE: PKW/SMART Programming Offline 12/2015 & 2016. Tested work. - MMdoc2 - 09-14-2021
(07-27-2016, 04:16 PM)pesona Wrote: Today i go to my friend to test this offline programming myself.
W204 and W211. Tested and it works.
Now, i need your help mates.
1. I was ask by a member here that he stumbled with release code and test digit 2, like this:
where do you get this numbers?
i think i know how to bypass it if i connect with the car and stumble with that.
but i need to know, if you don't bypass these numbers, where and how do you get this number from?
2. am i safe if don't connect battery charger?
offline programming commercial vehicles, wil begin after switch engine and start OFF. That's why i have peace in mind and don't need battery charger. for pkw, i read that the fan will on hardly etc etc..
i will continue with F3. but before that i need the information please.
Can somebody help me with test digit 2 code for to perform a software update of ETC  vgsnag2 in my car using DAS offline.. screen print attached. Can't found any solutions around
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - MMdoc2 - 09-14-2021
So can anybody help me with this test digit 2? Not for free
I already found the flash file that shown das to by used for update and tried to flash with vediamo. It start flash process and broke down... so now my ETC is down. DAS still alow me to the flash process but need test digit 2.
Fixed by local shop guy
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - SmartITA - 10-04-2021
PKW_SMART_TRANSP Offline Programming 2.5.txt
is goood for 06.2021?
